5.10.13 http 500 shared hosting imagick
hi
5.10.13 was working fine until I added some webhooks to/from postmark
is imagick mandatory?
cron
cd /home/invoice.ninja/public_html && /usr/local/php82/bin/php -d register_argc_argv=On artisan schedule:run > /dev/null 2>&1
$ php -d register_argc_argv=On artisan schedule:run
PHP Warning: PHP Startup: Unable to load dynamic library ‘imagick.so’ (tried: /usr/local/php82/lib/php/extensions/no-debug-non-zts-20220829/imagick.so (/usr/local/php82/lib/php/extensions/no-debug-non-zts-20220829/imagick.so: cannot open shared object file: No such file or directory), /usr/local/php82/lib/php/extensions/no-debug-non-zts-20220829/imagick.so.so (/usr/local/php82/lib/php/extensions/no-debug-non-zts-20220829/imagick.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
INFO No scheduled commands are ready to run.
not much in laravel log
This looks like a warning, is it causing any issues?
was unable to login at all
had to restore a backup
see how it will go
thanks
