I’m running the latest on Ubuntu 20.04/Apache. I also have a previous v4 instance running on the same server just fine every time I install either via unzip or git (per your docs) I end up with the same 404 Not found error.
Are there any tips to point me in the right direction?
BTW, that was an excerpt from the main apache error log. The actual IN apache access/error logs show 0 bytes and have no content at all even though the proper information is detailed in the sites-available conf file. The same is true for my current working v4 instance on the same server.
Yes, it’s a simple environment and just as a test, I took my v4 instance and copied it into the new folder in the document root where I installed v5 into and it works so I know Apache seems to be OK with it. Also, I get the initial setup wizard but as soon as I click the finish or apply (can’t remember the button syntax) the screen just jumps to the 404.
I do notice that the info I enter in the setup form does get written to the .env file.
