Im testing the client portal but every time i try to register i get a 404 Error | Not found.
Im on hosted sharing.
I have pointed my subdomain.example.com to public using .htaccess that’s in the root of Invoice Ninja files.
RewriteEngine On
RewriteCond %{REQUEST_URI} !^/public/
RewriteRule ^(.*)$ /public/$1 [L,R=301]
I’m not good at computer languages so if anyone can help me, it would be appreciated.
April 3, 2021, 6:33pm
Are you saying the admin portal does work but the client portal does not, have you made any changes?
@david any thoughts?
david
April 3, 2021, 9:11pm
3
need more info, is the site in a subdirectory? if it is, then the rewrite needs to also include the subdirectory.
Admin portal works but not the client when registering.
I can see the client portal by opening an invoice and choose Client Portal in the menu
This is a fresh V5 installation and im facing few issues. I haven’t made any changes to the files.
Issues:
Email sending not working: I received the initial testing email during installation.
Client not receiving invoice.
No confirmation email when created a new admin user
Client cant register at
Register — Invoice Ninja
Totally the same problem, fresh install and pretty much nothing works.
Ok, well, threw away the softaculous install as it was V5.1.31 which I had all the problems with. installed from the .zip release version and everything works!!! although i am in the early days of testing, IT WORKS!!!. now the only issue is customisation. Would love to know where the email templates are so i can make the necessary changes to CSS/HTML etc to make this work for my project.
April 7, 2021, 5:59am
7
You can set custom CSS/HTML by selecting the ‘custom’ email design on Settings > Email Settings.
Note: make sure to include $body so the app can inject the templates.
