2FA fallback / account recovery?
maybe a rather simple question: I would like to activate 2FA on my self-hosted Invoiceninja V5 instance. I am just wondering what would be the fallback solution if i.e. my lovely smartphone I am going to use for 2FA token creation will get lost? There is the standard Invoiceninja password recovery function via “provide your e-mail for passwort recovery” being part of the Invoiceninja login page. Does this still work with 2FA activated user lost his 2FA App/Mobile phone?
If not is there any other workaround for this kind of user?
Kind regards,
Nobunaga
As a workaround you could manually disable 2FA for the user by updating the database directly.
thanx for your quick answer! Does the workaround posted by you one year ago for V4 still work with Invoiceninja V5?
update users set google_2fa_secret = null, remember_2fa_token = null where email = ‘your_email’;
Kind regards,
Nobunaga
I’m not sure, you’ll need to check the v5 column field names, It should be similar.
