Can't Update Clients in Flutter or React
After upgrading today, updating clients suddenly give this in React:
This error occurs now in Flutter:
422: Unprocessable Content • The given data was invalid. • The id number has already been taken.
I’m not using the ID Number field and never have.
Flutter: v5.8.36-C156
@david do you have any ideas?
Yo!
+1
Tried with Flutter v5.8.36-C156
tried to add phone-number for yet existing client/customer.
tried to add internal/private memo/note to another.
But works with vendors!
All of them with individually given unique IDs/numbers when migrating/copying them manually field by field from an external/former app a week or so ago. I often hit “save” in between when it was < 36-C156 with no issues.
best regards!
Marcel Naranjo
www.dig-it.de
Bildschirmfoto_2024-03-14_14-16-07
We are seeing the same issue
This most likely means you have clients with the same id_numbers in the system. if you change (or remove) the id_number it should update
I’m having the same issue. I did try removing the id_number (Labeled as “Number” right under the name field) and I got the same error. I’m on a fresh build, just spun this up last night.
We do not use id_numbers. If i create a new customer Invoiceninja adds the next available number to that field but immediately after saving I cannot make changes to the new customer without getting the same error. I also get the same error if i remove the id_number. Thanks.
I can confirm that when I reverted back to the older docker image “5.8.35”, the error doesn’t show up anymore. You can update clients. I was running into the same issue when trying to update clients.
I’ve tagged a new release with a fix for this.
Works now, after updating this morning.
thanks for the quick solution.
best regards!
Thanks heaps @david - works here!
