I have a hosted account on V5, when trying to connect Zapier I get the error:
Authentication failed: Your API token is not valid, please check the value in Invoice Ninja on /settings/api_tokens.
I feel like the Zapier wizard is trying to force the connection to use the old InvoiceNinja.com rather than the invoicing.co.
I was attempting to make a API Token, but I don’t know the correct URL to use. Can anyone give me any guidance on this? Thanks in advance.
Hey Hillel,
Thanks for the reply. I was able to make an API, but Zapier only seems to want to connect to the V4 version of Invoice Ninja. I took a screenshot of the Zapier wizard. I tried adding my API Token, but I only get the response “authentication failed: Your API token is not valid, please check the value in Invoice Ninja on /settings/api_tokens.” which seems to also indicate it’s trying to connect to the V4 version, not the V5 version.
Yea, I’ve asked for advise there too. It appears they think it’s a issue with Invoice Ninja, while Invoice Ninja seems to think its a issue with Zapier. Just to clear it up, when you do a search on their site do you see “Invoice ninja V5” ? I only see one result pop-up, when I click it I get the same popup window I attached before.
