In the invoice overview, “Offer” is displayed instead of “Invoice”:
Hi @lucaw,
are you sure you are using v5.3.1-C58?
I have been experiencing this error since I updated from v5.3.0-C58 to v5.3.1-C58.
I have reproduced this in a second test installation. Also there with v5.3.0-C58 the correct text was displayed and directly after the update to v5.3.1-C58 the wrong value.
Strange. I have reproduced it in two installations that with 5.3.0 still the correct text was present and directly after the update to 5.3.1 the wrong text was displayed.
Is there a way to correct the text, if so where?
