Everywhere the currency form is OK. Like 100,00 €. (number,decimals_space_currency)
Only inside Quote View as recipient it will show as €100,00 (like USD form)
Probably a bug.
Br,
Dali
Probably a bug.
Br,
Dali
The placement of the currency symbol should be determined by the client’s country.
Are you sure you’re only seeing this for quotes and not invoices?
Yes, only in View as recipient. For both quote and invoice.
Preview and Exported PDF is OK.
I can send the screenshots.
Br,
Dali
I’ll take a look.
Which countries have you set for the company and the client?
One client have English other client have Slovenian (I copied and modified English one and ad it to the database as you suggested).
I believe it’s the same with German language when I was trying if that’s the problem.
Thank you
Br,
Dali
We base the formatting off the countries, not languages.
Inside Quote View as recipient? Currency formatting is the same no matter what country or language I chose for the client or my company.
Everywhere the currency form is OK. 100,00 €. (number,decimals_space_currency)
Only inside Quote View as recipient it will show as €100,00 (currency number,decimals)
Can you point me to a code where formatting gets defined for Quote View as recipient?
Thank you
Br,
Dali
Sorry for the trouble, I’ve just checked in a fix for the problem.
https://github.com/invoiceninja/invoiceninja/commit/1000ff40887079550c1f29804942a0c0fb0e6a2b
Perfect !!!
Great support!!! Thank you!
