i have some truble with selfhosted Ininja 4.5.14 on debian 10 with mariadb and php7.2.
After migration from debian 9 to 10, evrything works fine.
After a couple of days, i wrote an invoce and there was a problem withe the curency symbol (in german we use , fore decimal .) after some try, i used decimal. and i could print the invoce.
Since that day, (2-3 weeks ago) i allways get the same error.
After changing php from standard debian 10 (php7.3) to php7.2 ther was no way to bring invoceninja back to live.
So i try to find out dig deeper.
This is a peace of a new errorlog, and it seems, ther was a problem with the currecy symbol!
(1/1) ErrorException
file_put_contents(/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7): failed to open stream: No such file or directory
in Filesystem.php (line 122)
at HandleExceptions->handleError(2, ‘file_put_contents(/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7): failed to open stream: No such file or directory’, ‘/srv/ninja/code/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php’, 122, array(‘path’ => ‘/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7’, ‘contents’ => ‘9999999999O:39:“Illuminate\Database\Eloquent\Collection”:1:{s:8:"’ . “\0” . ‘’ . “\0” . ‘items";a:101:{i:0;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:1;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:2;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:3;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:4;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:5;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:6;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:7;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:8;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:9;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:10;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:11;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:12;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:13;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:14;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:15;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:16;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:17;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:18;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:19;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:20;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:21;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:22;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:23;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:24;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:25;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:26;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:27;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:28;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:29;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:30;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:31;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:32;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:33;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:34;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:35;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:36;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:37;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:38;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:39;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:40;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:41;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:42;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:43;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:44;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:45;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:46;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:47;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:48;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:49;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:50;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:51;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:52;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:53;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:54;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:55;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:56;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:57;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:58;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:59;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:60;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:61;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:62;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:63;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:64;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:65;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:66;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:67;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:68;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:69;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:70;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:71;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:72;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:73;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:74;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:75;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:76;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:77;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:78;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:79;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:80;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:81;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:82;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:83;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:84;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:85;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:86;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:87;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:88;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:89;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:90;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:91;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:92;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:93;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:94;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:95;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:96;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:97;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:98;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:99;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:100;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}}}’, ‘lock’ => true))
at file_put_contents(’/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7’, ‘9999999999O:39:“Illuminate\Database\Eloquent\Collection”:1:{s:8:"’ . “\0” . '’ . “\0” . ‘items";a:101:{i:0;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:1;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:2;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:3;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:4;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:5;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:6;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:7;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:8;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:9;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:10;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:11;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:12;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:13;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:14;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:15;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:16;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:17;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:18;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:19;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:20;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:21;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:22;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:23;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:24;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:25;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:26;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:27;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:28;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:29;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:30;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:31;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:32;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:33;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:34;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:35;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:36;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:37;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:38;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:39;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:40;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:41;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:42;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:43;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:44;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:45;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:46;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:47;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:48;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:49;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:50;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:51;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:52;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:53;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:54;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:55;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:56;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:57;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:58;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:59;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:60;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:61;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:62;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:63;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:64;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:65;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:66;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:67;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:68;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:69;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:70;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:71;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:72;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:73;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:74;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:75;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:76;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:77;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:78;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:79;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:80;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:81;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:82;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:83;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:84;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:85;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:86;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:87;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:88;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:89;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:90;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:91;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:92;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:93;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:94;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:95;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:96;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:97;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:98;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:99;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}i:100;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . ‘’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . '’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . ‘’ . “\0” . ‘table";N;s:13:"’ . “\0” . '’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . ‘’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . '’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . ‘’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . '’ . “\0” . ‘original";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . ‘’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . '’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . ‘’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . ‘’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . '’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . '’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . 'guarded";a:1:{i:0;s:1:"";}}}}’, 2)in Filesystem.php (line 122)
at Filesystem->put(’/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7’, ‘9999999999O:39:“Illuminate\Database\Eloquent\Collection”:1:{s:8:"’ . “\0” . ‘’ . “\0” . ‘items";a:101:{i:0;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:94;s:4:“name”;s:12:“Albanian Lek”;s:6:“symbol”;s:2:“L “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ALL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:1;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:90;s:4:“name”;s:14:“Algerian Dinar”;s:6:“symbol”;s:2:“DA”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:2;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:82;s:4:“name”;s:14:“Angolan Kwanza”;s:6:“symbol”;s:2:“Kz”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“AOA”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:3;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:23;s:4:“name”;s:14:“Argentine Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ARS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:4;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:97;s:4:“name”;s:13:“Armenian Dram”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:5;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:40;s:4:“name”;s:13:“Aruban Florin”;s:6:“symbol”;s:5:“Afl. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:” “;s:17:“decimal_separator”;s:1:”.”;s:4:“code”;s:3:“AWG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:6;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:12;s:4:“name”;s:17:“Australian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AUD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:7;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:98;s:4:“name”;s:16:“Azerbaijan Manat”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AZN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:8;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:77;s:4:“name”;s:14:“Bahraini Dinar”;s:6:“symbol”;s:3:“BD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BHD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:9;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:24;s:4:“name”;s:16:“Bangladeshi Taka”;s:6:“symbol”;s:2:“Tk”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BDT”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:10;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:71;s:4:“name”;s:16:“Barbadian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BBD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:11;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:100;s:4:“name”;s:16:“Belarusian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BYN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:12;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:93;s:4:“name”;s:18:“Bolivian Boliviano”;s:6:“symbol”;s:2:“Bs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BOB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:13;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:99;s:4:“name”;s:39:“Bosnia and Herzegovina Convertible Mark”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BAM”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:14;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:68;s:4:“name”;s:13:“Botswana Pula”;s:6:“symbol”;s:1:“P”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BWP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:15;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:20;s:4:“name”;s:14:“Brazilian Real”;s:6:“symbol”;s:2:“R$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“BRL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:16;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:2;s:4:“name”;s:13:“British Pound”;s:6:“symbol”;s:2:“£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:17;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:72;s:4:“name”;s:13:“Brunei Dollar”;s:6:“symbol”;s:2:“B$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“BND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:18;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:39;s:4:“name”;s:13:“Bulgarian Lev”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”.";s:4:“code”;s:3:“BGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:19;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:9;s:4:“name”;s:15:“Canadian Dollar”;s:6:“symbol”;s:2:“C$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:20;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:88;s:4:“name”;s:19:“Cape Verdean Escudo”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:"$";s:4:“code”;s:3:“CVE”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:21;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:86;s:4:“name”;s:9:“CFP Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XPF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:22;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:62;s:4:“name”;s:12:“Chilean Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“CLP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:23;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:32;s:4:“name”;s:16:“Chinese Renminbi”;s:6:“symbol”;s:4:“RMB “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CNY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:24;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:30;s:4:“name”;s:14:“Colombian Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“COP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:25;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:47;s:4:“name”;s:18:“Costa Rican Colón”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CRC”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:26;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:43;s:4:“name”;s:13:“Croatian Kuna”;s:6:“symbol”;s:2:“kn”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HRK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:27;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:51;s:4:“name”;s:12:“Czech Koruna”;s:6:“symbol”;s:3:“Kč”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“CZK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:28;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:5;s:4:“name”;s:12:“Danish Krone”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“DKK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:29;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:61;s:4:“name”;s:14:“Dominican Peso”;s:6:“symbol”;s:3:“RD$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“DOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:30;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:37;s:4:“name”;s:21:“East Caribbean Dollar”;s:6:“symbol”;s:3:“EC$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XCD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:31;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:29;s:4:“name”;s:14:“Egyptian Pound”;s:6:“symbol”;s:3:“E£”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“EGP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:32;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:3;s:4:“name”;s:4:“Euro”;s:6:“symbol”;s:3:“€”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“EUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:33;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:92;s:4:“name”;s:13:“Fijian Dollar”;s:6:“symbol”;s:3:“FJ$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“FJD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:34;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:73;s:4:“name”;s:13:“Georgian Lari”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“GEL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:35;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:38;s:4:“name”;s:13:“Ghanaian Cedi”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GHS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:36;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:101;s:4:“name”;s:15:“Gibraltar Pound”;s:6:“symbol”;s:3:“GIP”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:0:"";s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:37;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:18;s:4:“name”;s:18:“Guatemalan Quetzal”;s:6:“symbol”;s:1:“Q”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“GTQ”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:38;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:83;s:4:“name”;s:14:“Haitian Gourde”;s:6:“symbol”;s:1:“G”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HTG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:39;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:75;s:4:“name”;s:16:“Honduran Lempira”;s:6:“symbol”;s:1:“L”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HNL”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:40;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:26;s:4:“name”;s:16:“Hong Kong Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“HKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:41;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:69;s:4:“name”;s:16:“Hungarian Forint”;s:6:“symbol”;s:2:“Ft”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“HUF”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:42;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:63;s:4:“name”;s:16:“Icelandic Króna”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ISK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:43;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:11;s:4:“name”;s:12:“Indian Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“INR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:44;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:27;s:4:“name”;s:17:“Indonesian Rupiah”;s:6:“symbol”;s:2:“Rp”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“IDR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:45;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:6;s:4:“name”;s:14:“Israeli Shekel”;s:6:“symbol”;s:4:“NIS “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ILS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:46;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:81;s:4:“name”;s:15:“Jamaican Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JMD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:47;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:45;s:4:“name”;s:12:“Japanese Yen”;s:6:“symbol”;s:2:“¥”;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JPY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:48;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:65;s:4:“name”;s:15:“Jordanian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“JOD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:49;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:8;s:4:“name”;s:15:“Kenyan Shilling”;s:6:“symbol”;s:4:“KSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:50;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:89;s:4:“name”;s:13:“Kuwaiti Dinar”;s:6:“symbol”;s:2:“KD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“KWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:51;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:96;s:4:“name”;s:14:“Lebanese Pound”;s:6:“symbol”;s:3:“LL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LBP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:52;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:59;s:4:“name”;s:15:“Macanese Pataca”;s:6:“symbol”;s:4:“MOP$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MOP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:53;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:91;s:4:“name”;s:16:“Macedonian Denar”;s:6:“symbol”;s:6:“ден”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MKD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:54;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:19;s:4:“name”;s:17:“Malaysian Ringgit”;s:6:“symbol”;s:2:“RM”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MYR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:55;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:46;s:4:“name”;s:17:“Maldivian Rufiyaa”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MVR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:56;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:87;s:4:“name”;s:15:“Mauritian Rupee”;s:6:“symbol”;s:2:“Rs”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MUR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:57;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:28;s:4:“name”;s:12:“Mexican Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MXN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:58;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:80;s:4:“name”;s:15:“Moroccan Dirham”;s:6:“symbol”;s:4:“MAD “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:59;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:56;s:4:“name”;s:18:“Mozambican Metical”;s:6:“symbol”;s:2:“MT”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“MZN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:60;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:66;s:4:“name”;s:12:“Myanmar Kyat”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“MMK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:61;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:53;s:4:“name”;s:15:“Namibian Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NAD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:62;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:85;s:4:“name”;s:14:“Nepalese Rupee”;s:6:“symbol”;s:4:“Rs. “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NPR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:63;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:35;s:4:“name”;s:29:“Netherlands Antillean Guilder”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“ANG”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:64;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:15;s:4:“name”;s:18:“New Zealand Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NZD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:65;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:22;s:4:“name”;s:14:“Nigerian Naira”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“NGN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:66;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:14;s:4:“name”;s:13:“Norske Kroner”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“NOK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:67;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:57;s:4:“name”;s:10:“Omani Rial”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“OMR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:68;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:48;s:4:“name”;s:15:“Pakistani Rupee”;s:6:“symbol”;s:3:“Rs “;s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PKR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:69;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:64;s:4:“name”;s:22:“Papua New Guinean Kina”;s:6:“symbol”;s:1:“K”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PGK”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:70;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:67;s:4:“name”;s:12:“Peruvian Sol”;s:6:“symbol”;s:3:“S/ “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PEN”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:71;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:10;s:4:“name”;s:15:“Philippine Peso”;s:6:“symbol”;s:2:“P “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“PHP”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:72;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:49;s:4:“name”;s:12:“Polish Zloty”;s:6:“symbol”;s:3:“zł”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:" “;s:17:“decimal_separator”;s:1:”,";s:4:“code”;s:3:“PLN”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:73;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:74;s:4:“name”;s:12:“Qatari Riyal”;s:6:“symbol”;s:2:“QR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“QAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:74;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:42;s:4:“name”;s:16:“Romanian New Leu”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RON”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:75;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:55;s:4:“name”;s:13:“Russian Ruble”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RUB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:76;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:33;s:4:“name”;s:13:“Rwandan Franc”;s:6:“symbol”;s:3:“RF “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“RWF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:77;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:44;s:4:“name”;s:11:“Saudi Riyal”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:78;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:95;s:4:“name”;s:13:“Serbian Dinar”;s:6:“symbol”;s:3:“din”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“RSD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:79;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:13;s:4:“name”;s:16:“Singapore Dollar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“SGD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:80;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:4;s:4:“name”;s:18:“South African Rand”;s:6:“symbol”;s:1:“R”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZAR”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:81;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:79;s:4:“name”;s:16:“South Korean Won”;s:6:“symbol”;s:2:“W “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“KRW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:82;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:50;s:4:“name”;s:16:“Sri Lankan Rupee”;s:6:“symbol”;s:3:“LKR”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“LKR”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:83;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:76;s:4:“name”;s:17:“Surinamese Dollar”;s:6:“symbol”;s:3:“SRD”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SRD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:84;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:7;s:4:“name”;s:13:“Swedish Krona”;s:6:“symbol”;s:2:“kr”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“SEK”;s:20:“swap_currency_symbol”;i:1;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:85;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:17;s:4:“name”;s:11:“Swiss Franc”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:"’";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“CHF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:86;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:60;s:4:“name”;s:17:“Taiwan New Dollar”;s:6:“symbol”;s:3:“NT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TWD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:87;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:34;s:4:“name”;s:18:“Tanzanian Shilling”;s:6:“symbol”;s:4:“TSh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TZS”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:88;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:21;s:4:“name”;s:9:“Thai Baht”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“THB”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:89;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:36;s:4:“name”;s:26:“Trinidad and Tobago Dollar”;s:6:“symbol”;s:3:“TT$”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TTD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:90;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:54;s:4:“name”;s:14:“Tunisian Dinar”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“TND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:91;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:41;s:4:“name”;s:12:“Turkish Lira”;s:6:“symbol”;s:3:“TL “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”.”;s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“TRY”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:92;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:70;s:4:“name”;s:16:“Ugandan Shilling”;s:6:“symbol”;s:4:“USh “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UGX”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:93;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:58;s:4:“name”;s:17:“Ukrainian Hryvnia”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“UAH”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:94;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:25;s:4:“name”;s:27:“United Arab Emirates Dirham”;s:6:“symbol”;s:3:“DH “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“AED”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:95;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:52;s:4:“name”;s:14:“Uruguayan Peso”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“UYU”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:96;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:1;s:4:“name”;s:9:“US Dollar”;s:6:“symbol”;s:1:"$";s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“USD”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:97;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:78;s:4:“name”;s:19:“Venezuelan Bolivars”;s:6:“symbol”;s:3:“Bs.”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VES”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:98;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:16;s:4:“name”;s:15:“Vietnamese Dong”;s:6:“symbol”;s:0:"";s:9:“precision”;s:1:“0”;s:18:“thousand_separator”;s:1:".";s:17:“decimal_separator”;s:1:",";s:4:“code”;s:3:“VND”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:99;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:31;s:4:“name”;s:18:“West African Franc”;s:6:“symbol”;s:4:“CFA “;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:”,”;s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“XOF”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"";}}i:100;O:19:“App\Models\Currency”:25:{s:10:“timestamps”;b:0;s:8:"’ . “\0” . '’ . “\0” . ‘casts";a:2:{s:20:“swap_currency_symbol”;s:7:“boolean”;s:13:“exchange_rate”;s:6:“double”;}s:13:"’ . “\0” . ‘’ . “\0” . ‘connection";s:5:“mysql”;s:8:"’ . “\0” . '’ . “\0” . ‘table";N;s:13:"’ . “\0” . ‘’ . “\0” . ‘primaryKey";s:2:“id”;s:10:"’ . “\0” . '’ . “\0” . ‘keyType";s:3:“int”;s:12:“incrementing”;b:1;s:7:"’ . “\0” . ‘’ . “\0” . ‘with";a:0:{}s:12:"’ . “\0” . '’ . “\0” . ‘withCount";a:0:{}s:10:"’ . “\0” . ‘’ . “\0” . ‘perPage";i:15;s:6:“exists”;b:1;s:18:“wasRecentlyCreated”;b:0;s:13:"’ . “\0” . '’ . “\0” . ‘attributes";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:11:"’ . “\0” . ‘’ . “\0” . ‘original";a:9:{s:2:“id”;i:84;s:4:“name”;s:14:“Zambian Kwacha”;s:6:“symbol”;s:2:“ZK”;s:9:“precision”;s:1:“2”;s:18:“thousand_separator”;s:1:",";s:17:“decimal_separator”;s:1:".";s:4:“code”;s:3:“ZMW”;s:20:“swap_currency_symbol”;i:0;s:13:“exchange_rate”;N;}s:8:"’ . “\0” . '’ . “\0” . ‘dates";a:0:{}s:13:"’ . “\0” . ‘’ . “\0” . ‘dateFormat";N;s:10:"’ . “\0” . '’ . “\0” . ‘appends";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘events";a:0:{}s:14:"’ . “\0” . '’ . “\0” . ‘observables";a:0:{}s:12:"’ . “\0” . ‘’ . “\0” . ‘relations";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘touches";a:0:{}s:9:"’ . “\0” . ‘’ . “\0” . ‘hidden";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘visible";a:0:{}s:11:"’ . “\0” . ‘’ . “\0” . ‘fillable";a:0:{}s:10:"’ . “\0” . '’ . “\0” . ‘guarded";a:1:{i:0;s:1:"*";}}}}’, true)in FileStore.php (line 66)
at FileStore->put(‘currencies’, object(Collection), 0)in FileStore.php (line 120)
at FileStore->forever(‘currencies’, object(Collection))in Repository.php (line 267)
at Repository->forever(‘currencies’, object(Collection))in CacheManager.php (line 305)
at CacheManager->__call(‘forever’, array(‘currencies’, object(Collection)))in Facade.php (line 221)
at Facade::__callStatic(‘forever’, array(‘currencies’, object(Collection)))in StartupCheck.php (line 231)
at StartupCheck->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Pipeline{closure}(object(Request))in Pipeline.php (line 53)
at Pipeline->Illuminate\Routing{closure}(object(Request))in QueryLogging.php (line 32)
at QueryLogging->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in DuplicateSubmissionCheck.php (line 41)
at DuplicateSubmissionCheck->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in TransformsRequest.php (line 30)
at TransformsRequest->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in VerifyCsrfToken.php (line 65)
at VerifyCsrfToken->handle(object(Request), object(Closure))in VerifyCsrfToken.php (line 44)
at VerifyCsrfToken->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in ShareErrorsFromSession.php (line 49)
at ShareErrorsFromSession->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in StartSession.php (line 64)
at StartSession->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in AddQueuedCookiesToResponse.php (line 37)
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in EncryptCookies.php (line 59)
at EncryptCookies->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in Pipeline.php (line 102)
at Pipeline->then(object(Closure))in Router.php (line 574)
at Router->runRouteWithinStack(object(Route), object(Request))in Router.php (line 533)
at Router->dispatchToRoute(object(Request))in Router.php (line 511)
at Router->dispatch(object(Request))in Kernel.php (line 176)
at Kernel->Illuminate\Foundation\Http{closure}(object(Request))in Pipeline.php (line 30)
at Pipeline->Illuminate\Routing{closure}(object(Request))in Debugbar.php (line 51)
at Debugbar->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in CheckForMaintenanceMode.php (line 46)
at CheckForMaintenanceMode->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->Illuminate\Routing{closure}(object(Request))in HandlePreflight.php (line 46)
at HandlePreflight->handle(object(Request), object(Closure))in Pipeline.php (line 148)
at Pipeline->then(object(Closure))in Kernel.php (line 151)
at Kernel->sendRequestThroughRouter(object(Request))in Kernel.php (line 116)
at Kernel->handle(object(Request))in index.php (line 51)
file_put_contents(/srv/ninja/code/storage/framework/cache/eb/de/ebdea3620f4144a57de2a68a23251f5df5b471a7): failed to open stream: No such file or directory’
That is right, there isnt a file with this name.
Best regards,
Dieter
