I’m getting this error right after the setup of the VM. I’ve added the info them on submit … BAM… here’s that LONG long long error…
Any solution out there ?
Whoops, looks like something went wrong.
2/2
QueryException in Connection.php line 669:
SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name ‘all_pages_footer’ (SQL: alter table accounts
add all_pages_footer
tinyint(1) not null, add all_pages_header
tinyint(1) not null, add show_currency_code
tinyint(1) not null, add pro_plan_trial
date null)
at Connection->runQueryCallback(‘alter table accounts
date null’, array(), object(Closure)) in Connection.php line 629
at Connection->run(‘alter table accounts
date null’, array(), object(Closure)) in Connection.php line 409
at Connection->statement(‘alter table accounts
date null’) in Blueprint.php line 83
at Blueprint->build(object(MySqlConnection), object(MySqlGrammar)) in Builder.php line 203
at Builder->build(object(Blueprint)) in Builder.php line 128
at Builder->table(‘accounts’, object(Closure)) in compiled.php line 6273
at Facade::__callStatic(‘table’, array(‘accounts’, object(Closure))) in 2016_01_27_173015_add_header_footer_option.php line 21
at Schema::table(‘accounts’, object(Closure)) in 2016_01_27_173015_add_header_footer_option.php line 21
at AddHeaderFooterOption->up() in Migrator.php line 147
at Migrator->runUp(‘2016_01_27_173015_add_header_footer_option’, ‘2’, false) in Migrator.php line 117
at Migrator->runMigrationList(array(‘2016_01_27_173015_add_header_footer_option’, ‘2016_02_01_135956_add_source_currency_to_expenses’, ‘2016_02_25_152948_add_client_password’, ‘2016_02_28_081424_add_custom_invoice_fields’, ‘2016_03_14_066181_add_user_permissions’, ‘2016_03_14_214710_add_support_three_decimal_taxes’), array(‘pretend’ => false, ‘step’ => false)) in Migrator.php line 86
at Migrator->run(’/var/www/html/ninja/database/migrations’, array(‘pretend’ => false, ‘step’ => false)) in MigrateCommand.php line 77
at MigrateCommand->fire()
at call_user_func_array(array(object(MigrateCommand), ‘fire’), array()) in compiled.php line 1235
at Container->call(array(object(MigrateCommand), ‘fire’)) in Command.php line 169
at Command->execute(object(ArrayInput), object(BufferedOutput)) in Command.php line 256
at Command->run(object(ArrayInput), object(BufferedOutput)) in Command.php line 155
at Command->run(object(ArrayInput), object(BufferedOutput)) in Application.php line 791
at Application->doRunCommand(object(MigrateCommand), object(ArrayInput), object(BufferedOutput)) in Application.php line 186
at Application->doRun(object(ArrayInput), object(BufferedOutput)) in Application.php line 117
at Application->run(object(ArrayInput), object(BufferedOutput)) in Application.php line 64
at Application->call(‘migrate’, array(’–force’ => true)) in Kernel.php line 159
at Kernel->call(‘migrate’, array(’–force’ => true)) in compiled.php line 6273
at Facade::__callStatic(‘call’, array(‘migrate’, array(’–force’ => true))) in AppController.php line 120
at Artisan::call(‘migrate’, array(’–force’ => true)) in AppController.php line 120
at AppController->doSetup()
at call_user_func_array(array(object(AppController), ‘doSetup’), array()) in compiled.php line 9333
at Controller->callAction(‘doSetup’, array()) in compiled.php line 9395
at ControllerDispatcher->call(object(AppController), object(Route), ‘doSetup’) in compiled.php line 9375
at ControllerDispatcher->Illuminate\Routing{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 52
at Pipeline->Illuminate\Routing{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in compiled.php line 9852
at Pipeline->then(object(Closure)) in compiled.php line 9376
at ControllerDispatcher->callWithinStack(object(AppController), object(Route), object(Request), ‘doSetup’) in compiled.php line 9363
at ControllerDispatcher->dispatch(object(Route), object(Request), ‘App\Http\Controllers\AppController’, ‘doSetup’) in compiled.php line 8450
at Route->runController(object(Request)) in compiled.php line 8437
at Route->run(object(Request)) in compiled.php line 8151
at Router->Illuminate\Routing{closure}(object(Request))
at Pipeline->then(object(Closure)) in compiled.php line 8152
at Router->runRouteWithinStack(object(Route), object(Request)) in compiled.php line 8143
at Router->dispatchToRoute(object(Request)) in compiled.php line 8133
at Router->dispatch(object(Request)) in compiled.php line 2391
at Kernel->Illuminate\Foundation\Http{closure}(object(Request))
at Pipeline->Illuminate\Routing{closure}(object(Request)) in Debugbar.php line 49
at Debugbar->handle(object(Request), object(Closure))
at call_user_func_array(array(object(Debugbar), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Pipeline{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 32
at Pipeline->Illuminate\Routing{closure}(object(Request)) in StartupCheck.php line 186
at StartupCheck->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartupCheck), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in DuplicateSubmissionCheck.php line 33
at DuplicateSubmissionCheck->handle(object(Request), object(Closure))
at call_user_func_array(array(object(DuplicateSubmissionCheck), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 3163
at VerifyCsrfToken->handle(object(Request), object(Closure)) in VerifyCsrfToken.php line 42
at call_user_func_array(array(object(VerifyCsrfToken), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 13290
at ShareErrorsFromSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(ShareErrorsFromSession), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 11846
at StartSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartSession), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 13029
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
at call_user_func_array(array(object(AddQueuedCookiesToResponse), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 12966
at EncryptCookies->handle(object(Request), object(Closure))
at call_user_func_array(array(object(EncryptCookies), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->Illuminate\Routing{closure}(object(Request)) in compiled.php line 3224
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
at call_user_func_array(array(object(CheckForMaintenanceMode), ‘handle’), array(object(Request), object(Closure))) in compiled.php line 9862
at Pipeline->then(object(Closure)) in compiled.php line 2338
at Kernel->sendRequestThroughRouter(object(Request)) in compiled.php line 2322
at Kernel->handle(object(Request)) in index.php line 53
1/2
PDOException in Connection.php line 408:
at PDOStatement->execute(array()) in Connection.php line 408
at Connection->Illuminate\Database{closure}(object(MySqlConnection), ‘alter table accounts
date null’, array()) in Connection.php line 662
Messages1TimelineExceptions2Views0RouteQueries34MailsSessionRequest295.2ms12.5MBPOST setup
