after buying / applying the license, is it saved in the database or somewhere on the filesystem?
Do I need to take any volumes into consideration when hosting on Docker? Don’t want to have to reapply the license on each container update.
It’s stored in the database, you shouldn’t need to reapply it.
perfect! thanks.
Will get the license once I’m done with my test environment.
