Hi.
I just noticed quotes and invoices does not open inside my website iFrame anymore? Don’t know when this happened or why.
https://www.invoiceninja.com/custom-url-yourbrand-invoiceninja-com/
I can not find setting to enter iframe link anymore?
Very strange.
Thank you
Br,
Dali
LINK tab is missing from Client Portal Section.
that’s where it was website setting.
https://website.com/invoice.html
In 3.2 LINK tab is not showing anymore.
Br,
Dali
3
We hid the subdomain setting for self hosters in v3.2 (they should set the APP_URL value instead).
It looks like the website setting should still be shown though, we’ll include the change in v3.2.1.
Thank you, but it does not work
Current settings
APP_URL=https://website.com/payments/public
But it I change it to
APP_URL=http://website.com/invoice.html (iframe html) the link is
https://website.com/invoice.html/view/mh6weaeyqlfjwiykyp3jt9vw9mpvmwzg?silent=true
Correct URL should be:
https://website.com/invoice.html?mh6weaeyqlfjwiykyp3jt9vw9mpvmwzg
Thank you
Br,
Dali
5
The field will be added back in v3.2.1.
Yes, there also was a subdomain and website option. I guess that’s what’s missing in addition to APP_URL settings.
Thank you
Br,
Dali
9
You’re welcome, sorry for the trouble.
No problem at all.
I really appreciate your work put into InvoiceNinja and your support here on forum.
Br,
Dali
