Where did the System Settings go?
Hi.
I’m struggling to find System settings in v5. I would need to change SMTP settings.
I know I can manually edit .env, but how to test the mail sender?
Thank you
Br,
Dali
You would need to use the app to test it
Ok.
I copied SMPT settings from 4.5.35 to v5 .env. I’m logged inside the website. How to test it the settings are valid. If the email sends out well?
Also I’m struggling to find where can I change default user password. The one I created during the install. When I want to add another user it won’t allow saying Error 412: Invalid Password.
Thx
Correct, you can try emailing an invoice
You can change your password on Settings > User Details
We have a fix for the 412 error in the next release, one way to correct it is to logout and then back in
Thank you Hillel!
Br,
Dali
