Webcron Reminder not send
is it possible that the webcron Service don`t send reminders ?
My hoster allows only crons via http or https prototoll… can anybody explain the .env COMMAND_SECRET command ?
https://invoice-ninja.readthedocs.io/en/latest/configure.html
Those are the v4 docs but it looks like you’re using the v5 app, the relevant v5 docs are here:
okay thanks but why is the webcron not sending reminders, there is no entry in the log
@david do you have any ideas?
Is it only reminders that are affected? Do you send recurring invoices or use the automated auto billing?
yes it`s only reminders and yes i use the recurring invoice feature and this works perfect every 28. of each month. Auto billing is not in use, i set all my payments manully as payed
@sven.j
i’m not sure on this, the scheduler runs autobill/recurring/reminders.
can you take a screen shot of your reminder configuration in templates & reminders?
okay i thinks thats my fault… i not seen this settings… i have it enabled now i hope this works… thanks for your time
