Hello, i hope someone can help me,
im new here and i will use Invoice Ninja on my self Hosted web space. The porblem is, i have only acces over SFTP and web.
The Installation is finished and works, but i can´t start the cron job …
i do all i can find on the help page , i added the line in the .env but when i write /mydomain/invoiceninja/public/webcron?secret=mypassword on the site cron-job.org i get the answer 500 internal server error
or i write /mydomain/invoiceninja/webcron?secret=mypassword and get 404 Not found
can someone help me, what i can do
November 27, 2021, 4:36pm
If you’re seeing a 500 there may be more details in storage/logs
hi thx for the tip but i think i use the wrong adress
i use the site cron-job.org to initial the cron-job and at the moment i use the adress
https:// mydomain / invoiceninja/public
is this right?
and what exactly i have to change/add in the .htaccess ?
can you help me with this?
December 4, 2021, 10:13pm
4
@david can you please advise?
david
December 5, 2021, 10:40am
5
What is the error in the logs when the server returns the 500 error/
<head>
<!-- Error: -->
<script>
function gtag() {
</script>
<!-- Title -->
<title>Server Error</title>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="description" content=""/>
<!-- CSRF Token -->
<meta name="csrf-token" content="">
<!-- Scripts -->
<script src="https://mydomain/invoiceninja/public//js/app.js?id=0e3959ab851d3350364d" defer></script>
<script src="https://mydomain/invoiceninja/public/vendor/alpinejs@2.8.2/alpine.js" defer></script>
<!-- Fonts -->
<link rel="dns-prefetch" href="https://fonts.gstatic.com">
<link href="https://fonts.googleapis.com/css?family=Open+Sans&display=swap" rel="stylesheet" type="text/css">
<!-- Styles -->
<link href="https://mydomain/invoiceninja/public//css/app.css?id=5fe248ec24749bdc4086" rel="stylesheet">
<link rel="canonical" href="https://mydomain/invoiceninja/public/webcron"/>
<style >[wire\:loading], [wire\:loading\.delay], [wire\:loading\.inline-block], [wire\:loading\.inline], [wire\:loading\.block], [wire\:loading\.flex], [wire\:loading\.table], [wire\:loading\.grid] {display: none;}[wire\:loading\.delay\.shortest], [wire\:loading\.delay\.shorter], [wire\:loading\.delay\.short], [wire\:loading\.delay\.long], [wire\:loading\.delay\.longer], [wire\:loading\.delay\.longest] {display:none;}[wire\:offline] {display: none;}[wire\:dirty]:not(textarea):not(input):not(select) {display: none;}input:-webkit-autofill, select:-webkit-autofill, textarea:-webkit-autofill {animation-duration: 50000s;animation-name: livewireautofill;}@keyframes livewireautofill { from {} }</style>
<link rel="stylesheet" type="text/css" href="https://mydomain/invoiceninja/public/vendor/cookieconsent@3/cookieconsent.min.css" />
</head>
<style>
:root {
--primary-color: #1c64f2;
.bg-primary {
background-color: var(--primary-color);
.bg-primary-darken {
filter: brightness(90%);
.text-primary {
<body class="antialiased ">
<div class="grid lg:grid-cols-3">
<div class="hidden lg:block col-span-1 bg-red-100 h-screen">
<img src="https://mydomain/invoiceninja/public/images/client-portal-new-image.jpg"
class="w-full h-screen object-cover"
alt="Background image">
</div>
<div class="col-span-2 h-screen flex">
<div class="m-auto md:w-1/2 lg:w-1/4 flex flex-col items-center">
<span class="flex items-center text-2xl">
500 — Server Error </span>
<a class="button-link text-sm mt-2" href="https://mydomain/client">
Back to mydomain
</a>
</div>
</div>
</div>
<script {$nonce}>console.warn("Livewire: The published Livewire assets are out of date\n See: https://laravel-livewire.com/docs/installation/")</script><script src="https://mydomain/invoiceninja/public//vendor/livewire/livewire.js?id=21fa1dd78491a49255cd" data-turbo-eval="false" data-turbolinks-eval="false" ></script><script data-turbo-eval="false" data-turbolinks-eval="false" >window.livewire = new Livewire();window.Livewire = window.livewire;window.livewire_app_url = 'https://mydomain/invoiceninja/public/';window.livewire_token = '';window.deferLoadingAlpine = function (callback) {window.addEventListener('livewire:load', function () {callback();});};let started = false;window.addEventListener('alpine:initializing', function () {if (! started) {window.livewire.start();started = true;}});document.addEventListener("DOMContentLoaded", function () {if (! started) {window.livewire.start();started = true;}});</script>
<script src="https://mydomain/invoiceninja/public/vendor/cookieconsent@3/cookieconsent.min.js" data-cfasync="false"></script>
<script>
window.addEventListener("load", function(){
if (! window.cookieconsent) {
return;
window.cookieconsent.initialise({
"palette": {
"popup": {
"background": "#000"
"button": {
"background": "#f1d600"
"content": {
"href": "https://www.invoiceninja.com/privacy-policy/",
"message": "This website uses cookies to ensure you get the best experience on our website.",
"dismiss": "Got it!",
"link": "Learn more",
</script>
</body>
<footer>
</footer>
david
December 6, 2021, 1:49am
7
@calwi1981
The logs will be located in storage/logs/laravel.log this looks like the output from a webpage
is this the right one?
[2021-12-05 14:25:06] production.ERROR: set_time_limit(): Cannot set max execution time limit due to system policy {“exception”:"[object] (ErrorException(code: 0): set_time_limit(): Cannot set max execution time limit due to system policy at mydomain/app/Http/Controllers/WebCronController.php:60)
#0 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(2, ‘set_time_limit(…’, ‘/customers/2/5/…’, 60, Array)
#1 mydomain/app/Http/Controllers/WebCronController.php(60): set_time_limit(0)
#2 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\WebCronController->index(Object(Illuminate\Http\Request))
#3 mydomain/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction(‘index’, Array)
#4 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\WebCronController), ‘index’)
#5 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#6 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Routing\Route->run()
#7 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#8 mydomain/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#9 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#10 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#11 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#12 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#13 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest(Object(Illuminate\Http\Request), Object(Closure), Array)
#14 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ‘300’, ‘1’)
#15 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#16 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#17 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#18 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#19 mydomain/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#20 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#21 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#22 mydomain/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#23 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#24 mydomain/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#25 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#26 mydomain/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#27 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))
#28 mydomain/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#29 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#30 mydomain/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#31 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#32 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#33 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#34 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#35 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#36 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#39 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#42 mydomain/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#43 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#44 mydomain/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#45 mydomain/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#46 {main}
david
December 8, 2021, 2:21am
9
Wow, haven’t seen a host do this one before. That there is your problem.
OK, this is the same Message i get if i will do the migration in my working version of Invoiceninja V4.
Do you have any idea what i can do to fix this?
david
December 11, 2021, 8:48pm
11
@calwi1981
This problem is with your webhost. They have disabled the function set_time_limit() completely which is quite a concern. Usually if a webhost doesn’t want you to use a particular function, they can set ignore filters which will still allow the application to work, but this particular setting makes the application incompatible with your hosting infrastructure.
david:
mhhh ok, thanks.
and how long can use the version 4
OK, i talked with my hosting company, and they say, there is set a max execution time of 300 Sekunden, and it is not posible to change this. So is there anything i can change in the script that it works with that configuration of the server?
david
January 2, 2022, 11:39pm
14
The problem isn’t the limits, the problem here is they have disabled access to the set_time_limit() function which automatically kills the application
