Is voice commands available in the open source version of invoice ninja?
Thanks!
Thanks!
Yes, however you need to train your own model.
There’s some basic info here:
http://docs.invoiceninja.com/en/latest/configure.html#voice-commands
Thanks for the info. I’ve created a LUIS.ai app on there website. When I click on the “Import New App” button and import the json file you guys provide the website throws this error: BadArgument: Failed to parse application json. Parameter name: applicationJsonString. Would you happen to know where I would need to import that json?
Not sure, I’ll look into it…
It looks like LUIS.ai now supports public applications, please try using this app id: ea1cda29-5994-47c4-8c25-2b58ae7ae7a8
That worked!
For the MSBOT_LUIS_SUBSCRIPTION_KEY I was able to get that information by signing up and logging into Luis.ai. Then click your name in the top right corner of the screen and then click on Settings. I used the Authoring Key for the Subscription key.
Thanks Hillel for your help with this.
