Howdy! New IN convert (purchased the white label to support devs, and now trying to figure things out.)
I’d like to enable a couple gateways that don’t show by default. I’ve gone into the db and enabled a couple gateways that weren’t previously enabled, and disabled the ones that I know I won’t be using. I’ve cleared cache via ssh with compose, and also via the URL. My gateway select in Gateway setup is still showing the initial list though.
How do I get this list to show the selections configured in the db?
I see, so ONLY the ones showing in the list will work, the rest in there are basically a roadmap. I guess that makes sense, I may contribute the Coinbase gateway if I can get one of my guys on it.
What about the dropdown list of gateways though, how is that list modified?
Thanks David, If you check out the images I shared above, you can see that I DID set them to true. But even with that modification, the new gateways do NOT pull through to the frontend. Any ideas?
