I have been trying to get V5 up and running on my Centos 7.x OS with MySQL and php 7.3 but am still having issues with the 500 error. Does it require Centos 8 (Cpanel not supported), MariaDB?
By the way, this is a really great product you have. I have been using invoiceASAP but I think InvoiceNinja is a better product.
I am not seeing anything. The only thing that is in that directory is .gitignore. Just to be sure, I checked the ver 4.9 folder and looked in the storage/logs folder and found some content but that probably doesn’t relate to the fresh ver 5 folder. I don’t even get a setup page for the ver 5
I figured but just wanted to be sure and thanks for the link… I found that one but glad to know that is the correct list. Right now, am working on finding the missing modules so that I can get them installed.
