Hi Hillel,
I like to use a variable into the invoice footer.
I added Nr: $number
It don’t show the invoice number, only Nr:
Greetings, Koen
Hi Hillel,
I added Nr: $number
Greetings, Koen
Try $invoice.invoiceNumber
Tns, that did the job…
Maybe you can change this in the helpfile at the templatesettings.
The variable is listed in the help on /settings/customize_design
It’s different on /settings/templates_and_reminders
Those variables are for the email templates, not the invoice PDF.
ok, tnx very much
