Hello!
I found a bug with the custom fields.
When I create a custom field into invoice and put in the field only numbers, those numbers become the amount of the invoice.
For example
→ if the amount of the invoice is 500$
→ I put “12341234” in the custom field
→ the invoice amount becomes 12341234$
Am I doing something wrong or is there a snippet to fix that or will there be an update?
Thank you.
Thank you for your reply.
It’s not a surcharge field.
I posted the screenshot, you can notice the issue also by yourself in the demo version available online on the website.
