Hello !
I am trying to migrate my data from my V4 Instance to a freshly installed V5.
I created a user with same credentials and started the migration process.
There are 5 “companies” on my V4 Instance
Company 1 : Success !
Company 2 error email :
Undefined index: notifications
Company 3, 4 and 5 error email :
SQLSTATE[HY000] [1045] Access denied for user ‘ninja’@‘localhost’ (using password: YES) (SQL: select exists(select * from users
where (email
= info@kidjdk.be ) and users
.deleted_at
is null) as exists
) SQLSTATE[HY000] [1045] Access denied for user ‘ninja’@‘localhost’ (using password: YES) (SQL: select exists(select * from users
where (email
.deleted_at
is null) as exists
Can someone guide me on what to check /change to make this work ?
Thank you !
Florian
david
June 12, 2021, 11:18am
florianverdonck:
notifications
Are there any additional errors in the logs in your V5 installation in storage/logs/laravel.log
Hello @david ,
Thank your for your reply !
Here are some additional information from the laravel.log
[2021-06-12 05:09:02] production.INFO: db fails
[2021-06-12 05:10:35] production.INFO: file_put_contents(/var/www/invoicesv5.xxx.be/htdocs/.env): failed to open stream: Permission denied
[2021-06-12 05:10:35] production.INFO: SQLSTATE[HY000] [1045] Access denied for user ‘ninja’@‘localhost’ (using password: YES) (SQL: select * from information_schema.tables where table_schema = ninja and table_name = migrations and table_type = ‘BASE TABLE’)
[2021-06-12 05:10:42] production.INFO: db fails
[2021-06-12 05:11:24] production.INFO: db fails
[2021-06-12 05:17:06] production.INFO: db fails
[2021-06-12 05:18:09] production.INFO: SQLSTATE[HY000] [1045] Access denied for user ‘ninja’@‘localhost’ (using password: YES) (SQL: select * from information_schema.tables where table_schema = ninja and table_name = migrations and table_type = ‘BASE TABLE’)
[2021-06-12 05:25:46] production.INFO: latest version = 5.2.1
Hope this helps
Florian
david
June 12, 2021, 11:37am
4
ok,
this makes sense.
It looks like the permissions on the directory need to be writable by the webuser - the .env file isn’t being written.
Permissions on .env file are defined like this, do you see a problem with this line ?
-rw-r–r-- 1 www-data www-data 1453 Jun 12 07:15 .env
david
June 12, 2021, 12:00pm
6
The error indicates that the application isn’t able to write to the .env file… perhaps another user process is attempting to write?
