I’m on self-hosted (shared) using php cli 7.3. Tried to upgrade to 4.5.42 but got a bunch of errors so tried to roll back to my last working version which is 4.5.40 as I urgently needed it working but somehow it still gave errors.
There was an error log in the main folder
[02-Jul-2021 13:27:14 America/Chicago] PHP Fatal error: Out of memory (allocated 698359808) (tried to allocate 83886080 bytes) in phar:///opt/cpanel/composer/bin/composer/src/Composer/DependencyResolver/RuleSet.php on line 92
[02-Jul-2021 13:30:51 America/Chicago] PHP Fatal error: Out of memory (allocated 771760128) (tried to allocate 4096 bytes) in phar:///home3/irishblu/public_html/portal/composer.phar/src/Composer/DependencyResolver/Solver.php on line 201
These are in storage/logs laravel errors
[2021-07-03 00:00:22] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError [0] : /home3/irishblu/public_html/portal/vendor/fzaninotto/faker/src/Faker/Provider/en_US/Address.php [Line 5] => Class ‘Faker\Provider\Address’ not found {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“user_agent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.117 Safari/537.36”,“locale”:“en”,“ip”:"[iphere]",“count”:1,“is_console”:“yes”,“is_api”:“no”,“db_server”:“mysql”,“url”:"/"} []
[2021-07-03 05:26:58] production.ERROR: ErrorException [0] : /home3/irishblu/public_html/portal/vendor/anahkiasen/former/src/Former/MethodDispatcher.php [Line 104] => Class ‘Former\Form\Elements’ not found (View: /home3/irishblu/public_html/portal/resources/views/auth/login.blade.php) {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“user_agent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.114 Safari/537.36”,“locale”:“en”,“ip”:"[iphere]",“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”,“url”:“login”} []
These are the errors showing on the main site with app debug on
(2/2) ErrorException
Class 'Former\Form\Elements' not found (View: /home3/irishblu/public_html/portal/resources/views/auth/login.blade.php)
in MethodDispatcher.php line 104
at CompilerEngine->handleViewException(object(FatalThrowableError), 0)
in PhpEngine.php line 47
at PhpEngine->evaluatePath('/home3/irishblu/public_html/portal/storage/framework/views/d4e0bf59fe98449c1c235109a1bf23b094bf95de.php', array('__env' => object(Factory), 'app' => object(Application), 'errors' => object(ViewErrorBag)))
in CompilerEngine.php line 59
at CompilerEngine->get('/home3/irishblu/public_html/portal/resources/views/auth/login.blade.php', array('__env' => object(Factory), 'app' => object(Application), 'errors' => object(ViewErrorBag)))
in View.php line 137
at View->getContents()
in View.php line 120
at View->renderContents()
in View.php line 85
at View->render()
in Response.php line 42
at Response->setContent(object(View))
in Response.php line 206
at Response->__construct(object(View))
in Router.php line 724
at Router::toResponse(object(Request), object(View))
in Router.php line 698
at Router->prepareResponse(object(Request), object(View))
in Router.php line 658
at Router->Illuminate\Routing\{closure}(object(Request))
in Pipeline.php line 30
at Pipeline->Illuminate\Routing\{closure}(object(Request))
in RedirectIfAuthenticated.php line 59
at RedirectIfAuthenticated->handle(object(Request), object(Closure))
in Pipeline.php line 149
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
in Pipeline.php line 53
in StartupCheck.php line 241
at StartupCheck->handle(object(Request), object(Closure))
in QueryLogging.php line 32
at QueryLogging->handle(object(Request), object(Closure))
in DuplicateSubmissionCheck.php line 41
at DuplicateSubmissionCheck->handle(object(Request), object(Closure))
in TransformsRequest.php line 30
at TransformsRequest->handle(object(Request), object(Closure))
in VerifyCsrfToken.php line 68
at VerifyCsrfToken->handle(object(Request), object(Closure))
in VerifyCsrfToken.php line 44
in ShareErrorsFromSession.php line 49
at ShareErrorsFromSession->handle(object(Request), object(Closure))
in StartSession.php line 63
at StartSession->handle(object(Request), object(Closure))
in AddQueuedCookiesToResponse.php line 37
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
in EncryptCookies.php line 68
at EncryptCookies->handle(object(Request), object(Closure))
in Pipeline.php line 102
at Pipeline->then(object(Closure))
in Router.php line 660
at Router->runRouteWithinStack(object(Route), object(Request))
in Router.php line 635
at Router->runRoute(object(Request), object(Route))
in Router.php line 601
at Router->dispatchToRoute(object(Request))
in Router.php line 590
at Router->dispatch(object(Request))
in Kernel.php line 176
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
in InjectDebugbar.php line 51
at InjectDebugbar->handle(object(Request), object(Closure))
in CheckForMaintenanceMode.php line 46
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
in HandlePreflight.php line 46
at HandlePreflight->handle(object(Request), object(Closure))
in Kernel.php line 151
at Kernel->sendRequestThroughRouter(object(Request))
in Kernel.php line 116
at Kernel->handle(object(Request))
in index.php line 51
(1/2) FatalThrowableError
at MethodDispatcher->toElements('open', array('login'))
in Former.php line 123
at Former->__call('open', array('login'))
in Facade.php line 221
at Facade::__callStatic('open', array('login'))
in d4e0bf59fe98449c1c235109a1bf23b094bf95de.php line 7
at include('/home3/irishblu/public_html/portal/storage/framework/views/d4e0bf59fe98449c1c235109a1bf23b094bf95de.php')
in PhpEngine.php line 43
in View.php line 85
at View->render()
