Hello
I am trying to create a client from the API and setting the properties manually.
I successfully used the fields “country_code” and “currency_code” to send the ISO codes instead of the old way of getting the Id’s and they work well.
My problem is with the language, since I don’t know the id’s of the languages in InvoiceNinja and actually can’t find anyway to get them -a little bit tedious- I decided to use the same pattern “language_code” and whatever I send to this property there is no error but the language never get’s set.
for example I have tried to add a client with the language set as German so I have sent this in the request "language_code=“de” "
and in the response of the request it was to also stated that “language_code=“de”” but in the app it was not set and for the invoices the default language was used which is English.!
Is there anyway to get this to work since?
thank you
