Use custom field in template
I created a custom field in settings → custom fields → clients and want to use this custom field in templates & reminders. How can I find out the name of the variable?
Thanks in advance for your help!
I believe the field is $client.client1, you should see it listed in the variables help.
@ben @david could we also support $client.custom1, I think it’s a bit clearer.
Looks good to me, @david?
Your are right. Thanks for your help!
In the actual version 5.1.70-C51 the field $client.client1, doesn’t work anymore, although it is listed in the variables help.
Can someone confirm that this is a an issue?
I’m not sure since which update I’ve got this problem.
