Urgent: Broken UTF-8 (umlaute), also broken Invoice Design
Version ie <v5.11.11>
Environment
Checklist
after the last - as i assume Update - zu 5.11.11 the PDF Generation is broken, especially when it comes to umlaute, but as well the table generation are not running properly.
Same here, tables for products an service are all messed up.
Seems, that the content is outside the tables probably.
I restored 5.11.8 because even in 5.11.10 i had a problem with another div wich jumped to the left.
Thanks in advance for fixing it soon!
Best regards.
Marcel Naranjo
www.dig-it.de
Hi,.
I suggest following up in a discussion on GitHub
there are two issues:
a) Tables are broken
b) Umlaute äöü etc, ß are not handled properly anymore.
i assume the first problem is based on the second, as the basic template is running in preview (without äöüß etc) are runnig properly
I made a revers to 5.11.10. it’s fine again!
I’m experiencing the same issue. The discussion link reference above isn’t helpful or I might have seen the wrong post. In any case, the latest update broke the template design (5.11.11). It’s not practical to revert the entire app to v5.11.10 and risk data mix-up/re-creation.
Edit: I found this on the Cloudron forum. Please apply the merge request!
Thanks for sharing it!
cc @david
i am with you, but was the only way to solve it and as there relevant invoices…we did it now this way. it’s smooth, no data mix-up
