I am facing issue after upgrading the code base to the latest 5.5.84 version from 5.5.71 version when I am running php artisan ninja:post-update command in terminal nothing happens and just the prompt is giving back as it was.
If i try to update via browser using the url {domina name}/update?secert=supersecretpassword I get a 500 error page.
Also after upgrading when I try to check the version in my UI app it still shows the older one i.e. 5.5.71, and if I try to upgrade from the UI it never works.
You’ll first want to ensure all file permissions are correct and set the root directory to recursively be owned by the web user. If that does not resolve the issue, set APP_DEBUG=true in the .env file and run
sudo -u www-data php artisan optimize
then reattempt the update, the app should at least write the error to the log file which will give us a clue as to what is happening.
Any idea on the above error how can I fix this, upon googling I found that this is a common laravel error any many db related solution are available but want to know if this should be used or not.
