Morning
What is the process for upgrading from v4 to v5 please?
Morning
To upgrade from v4 you need to install v5 as a separate app and then use the migration tool in the latest version of v4 on Settings > Account Management.
I can setuo v5 easily enough then but would like to use the domain that v4 sits on, is that possible?
Yes, should be fine, after you have migrated, change your v5 APP_URL, and then re-upload your company logo.
So if I understand correctly… In broad strokes, here’s what I nbeed to do?
Couldn’t I just backup the database from v4, install v5 and then overwrite the database?
Is there a documented procedure for this? Where one can use the original domain where v4 sits?
As @hillel said, Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja contains the procedure.
Install your v5 instance on a temporary domain/subdomain, then once it is fully migrated and working, delete your old instance and change the APP_URL environment variable (and anything else you have for your routing). (Same as what @david said…)
