Hello all,
For anyone interested, upgrading to the newest Ubuntu 24.04 release causes some minor issues due to changes and updates to php8.3 as well as php-fpm. It is relatively easy to fix, but took me about 90 minutes to chase down where the errors were coming from. Initially, I had a black screen when going to the web interface and the mobile app only displayed the spinning wheel. I ended up discovering the error in the debug console in Firefox.
- Reinstall all php modules to php8.3 versions (older versions were automatically removed during upgrade - which was clearly noted in the upgrade logs)
- Move any custom php config files from php8.1 to php8.3
- Remove all of php8.1 (or older) and modules (as mentioned, this was automatically done during upgrade for me, but source folders needed to be removed)
- Edit your nginx or apache2 config file to direct to
php8.3-fpm.sock
and not an older version systemctl reload nginx (or apache2)
I hope this helps.
