Hi - When upgrading from 5.1.70 to 5.1.74 I get the following in laravel.log and the upgrade fails.
Cannot update system because CHANGELOG.md is not writable at /usr/share/nginx/invoiceninja/app/Http/Controllers/SelfUpdateController.php:104)
I’ve tried chmod 777 CHANGELOG.md, however the upgrade fails. I’ve noticed the permissions of other files is -rw-r-Sr–
I’ve set the permissions to match the other files in /invoiceninja
-rw-r-Sr-- 1 www-data www-data 2.3K May 30 11:51 CHANGELOG.md
However the update still fails with the same error.
Had a read into permissions, and it looks like a lowercase ‘s’ sets the groupid permissions.
setgid has no effect if the group does not have execute permissions. setgid is represented with a lower-case “s” in the output of ls. In cases where it has no effect it is represented with an upper-case “S”.
I ran chmod -R ug-s /invoiceninja which has resolved the permissions problem and I have been able to update successfully.
