You may want to check the permissions on the server
Hi, I have checked every where I know. I can save or create content everywhere except, in the settings. There is no error code logged. When I click on save, the browser goes blank, then i have to refresh, and the data is not saved.
Is there a place to create a help ticket?
This is the place to ask for help with selfhost support
Are there any errors in the browser console or in storage/logs?
The only information in storage log is:
laravel.log ( ASCII text )
[2025-07-28 23:30:02] production.INFO: updating currencies
[2025-07-29 06:20:02] production.INFO: Performing Autobilling 2025-07-29 06:20:02
Its only in settings that content won’t save. I check all permissions. Any other suggestions?
Are you still seeing the permissions error in the mobile app?
Yes, below is the error I get on mobile app:
Error: please check that Invoice Ninja v5 is installed on the server
URL: http://mirna.casalindacleaningservices.com/api/v1/companies/VolejRejNm?
Response: <br />
<b>Warning</b>: file_get_contents(): Unable to create temporary file, Check permissions in temporary files directory. in <b>/home/mirna/public_html/mirna.casalindacleaningservices.com/vendor/s
Headers: {connection: Upgrade, date: Tue, 29 Jul 2025 13:17:04 GMT, vary: Accept-Encoding, content-encoding: gzip, content-length: 263, x-robots-tag: noindex, nofollow, p3p: policyref="/w3c/p3p.xml", CP="IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT", content-type: text/html; charset=UTF-8, server: Apache, upgrade: h2,h2c}}
I’m not sure, here’s what ChatGPT suggests in case it’s helpful
That warning means PHP is trying to create a scratch file (for file_get_contents(), cURL, PDF generation, etc.) but the temp directory it thinks it should use either doesn’t exist, isn’t writable by the PHP‑FPM/CGI user, or is outside an open_basedir jail. The fix is to point PHP at a writable folder and make sure the web‑server user can write there.
1 ️⃣ Find out which temp folder PHP is using
php -r 'echo sys_get_temp_dir(), PHP_EOL;'
If that prints something like /tmp/systemd-private‑xxxx/tmp or even an empty string, PHP is relying on a folder that may not exist under your shared‑hosting jail.
2 ️⃣ Create a safe temp folder inside your account
mkdir -p /home/mirna/tmp
chmod 1777 /home/mirna/tmp # drwxrwxrwt, same as /tmp
(1777 gives “sticky‑bit” write access for every process but stops one user deleting another’s files.)
3 ️⃣ Tell PHP to use it
If you have a per‑domain php.ini or the cPanel “MultiPHP INI Editor”
; /home/mirna/public_html/php.ini
sys_temp_dir = "/home/mirna/tmp"
upload_tmp_dir = "/home/mirna/tmp"
Or via an .htaccess drop‑in
# .htaccess in public_html
php_value sys_temp_dir "/home/mirna/tmp"
php_value upload_tmp_dir "/home/mirna/tmp"
After saving, restart PHP‑FPM / kill .php-fpm processes from cPanel so the new settings are read.
4 ️⃣ Check open_basedir
Some shared hosts lock PHP into open_basedir=/home/mirna/:/tmp/.
If you set a custom temp folder, make sure that folder is inside the allowed paths or extend the rule.
5 ️⃣ Clear caches & retest
php artisan optimize:clear
Then try the action that was failing. If the warning disappears, you’re done.
Why this works
file_get_contents() (and lower‑level stream wrappers) call tmpfile() under the hood. When PHP can’t open a file in the temp dir it shows exactly the message you saw. The fix is always permission + correct path; several PHP users solved it simply by setting sys_temp_dir to a folder they own (Stack Overflow), and Stack Overflow answers explain that the error has nothing to do with FTP/Guzzle/Invoice Ninja itself but with PHP’s temp directory rights (Stack Overflow).
Quick checklist
| Item | Command / setting | Expected | |
| Temp dir exists & writable | ls -ld /home/mirna/tmp |
drwxrwxrwt |
| PHP uses that dir | `php -i | grep sys_temp_dir` | /home/mirna/tmp |
| Enough disk quota | df -h / cPanel “Disk Usage” |
Free space > 0 | |
| Not cleaned away by cron | crontab -l |
No aggressive /tmp cleanup |
If everything above is correct and the warning persists, double‑check SELinux/AppArmor rules or open a ticket with the host—they sometimes mount /tmp as noexec,nosuid,nodev, which can also block temp‑file creation.
Bottom line: point PHP at a folder you control, give it 1777 perms, and restart PHP. That eliminates the temp‑file warning in Invoice Ninja 99 % of the time.
Ok, give me some time to follow up with these suggestions. thanks
