Upgrade AWS Bitnami Instance
So I have read the instructions that say just copy the .zip file but what does that mean? Is the .zip file supposed to go into a certain directory on the Ubuntu server? Then what commands install it? Do I have to get FTP working with AWS to get the files up or are there specific SCP instructions?
Once the .zip file is uploaded does it have to go somewhere specifically? Do tools need to be installed on the server to unzip the file.
The documentation has been pretty solid but the upgrade instructions I just want to be sure of so I don’t mess anything up.
Have you seen this?
https://wiki.bitnami.com/Applications/Bitnami_Invoice_Ninja#How_to_upgrade_Invoice_Ninja
I’ve found this post which may be relevant
https://www.invoiceninja.com/forums/topic/update-invoice-ninja-on-bitnami-deployed-to-google-cloud-platform/
You may want to also post to Bitnami’s forum
https://community.bitnami.com/
Thanks. Yes I saw those but not super clear I don’t think. I will give it a shot and see how it goes.
