Updating Invoice Design
Hi…new to Invoice Ninja…looks like it will be great…once I get a handle on it.
I’m trying to update my invoice design, but the invoice seems to stick to the old one. I’ve tried to delete the invoice and set it again…but same problem.
So I came here and saw the suggestion to ‘save’ the invoice again and it should update to the new design…but no such luck.
Am I missing something here?
Any help is greatly appreciated!
Are you using Cloudflare?
https://invoiceninja.github.io/docs/self-host-troubleshooting/#pdfs-dont-appear-to-be-updating
Thanks.
Not using Cloudflare…but added the info for future reference. I’ve managed to change the design by assigning it under ‘settings’ within the invoice section itself. In doing that, all of the changes are now reflected (ie. design, terms etc…).
Cheers!
