Updated Templates & Reminders Settings won't Save
I’m attempting to modify the email subject and body used in the Templates for Quotes and Invoices BUT every time I click save the “Processing” banner shows up but never successfully saves.
This also applies to Quote columns and total fields as well
Please open the browser console and there is likely an error there that you should take screenshot of. Also, check storage/logs/laravel.log
That was the web console. I’ll check the error logs but I noticed that the settings update as they should when using the mobile version
I don’t see any screenshots, please share.
Here are instructions for checking the browser console for error messages:
How to Check JavaScript Errors in Browser Console - BugMonitor (bug-monitor.com)
you will also want to check storage/logs/laravel.log
