Thanks, @david! That’s good to know. Maybe you want to add that to the user guide, as many users might have the same questions.
In the meantime I overwrote the existing files with the latest version. Although I set the php version to 8.1 in my .htaccess file, I get this error: Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.1.0".
But I guess I’ll be able to solve that.
Thanks a lot for your support!
Some (positive) update. Since last time Siteground added php 8.2 (default is still 7.4.30) so I tried to update again. It didn’t go well, I got same error as before, but when I changed php to 8.2 for my whole domain (not just subdomain where IN is installed) and refreshed site everything started working fine.
Or better, almost fine.
Soon I got a notification from Cron Deamon:
Fatal error: Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.1.0". You are running 7.4.30. in /home/customer/www/X/public_html/vendor/composer/platform_check.php on line 24
I changed in cronjob command /usr/bin/php to /usr/bin/php82 and notification changed to:
INFO Processing jobs from the [default] queue.
I did another change to /usr/local/php82/bin/php and now I am getting:
Content-type: text/html; charset=UTF-8
Before that I was not getting any notifications and this is at least annoying.
