I’m trying to update a self hosted installation from v5.46 to v5.5.49
Yes I checked health and it all seems ok… see below
At first it complained that “pakages.php” is not writable … however it is, see below …
Anyhow just to make sure that it is writable by everyone I changed the permissions to “777” and tried the update again … it took a long time and it seem to beworking… then a message flashed by 'Server Error" then disappeared the screen went gray and it returned to the app, which I’m running in web browser (Firefox V108.0.1) without completing the update …
When I look in the laravel log the following message pops out …
[2022-12-21 04:30:24] production.ERROR: chmod(): Operation not permitted {“userId”:1,“exception”:"[object] (ErrorException(code: 0): chmod(): Operation not permitted at /var/www/invoiceninja/vendor/nelexa/zip/src/ZipFile.php:456)
It seems like it is trying to modify the permissions of “ZipFile.php” why??
Anyhow … it refuses to update …
Anyone else have this issue?
btw … the whole log is below the line of asterisks
#0 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(259): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /var/www/invoiceninja/vendor/nelexa/zip/src/ZipFile.php(456): chmod()
#3 /var/www/invoiceninja/app/Http/Controllers/SelfUpdateController.php(111): PhpZip\ZipFile->extractTo()
#4 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\SelfUpdateController->update()
#5 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#6 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#7 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(19): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#8 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#9 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#10 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#11 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(798): Illuminate\Routing\Route->run()
#12 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#13 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest()
#15 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#16 /var/www/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle()
#18 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#20 /var/www/invoiceninja/app/Http/Middleware/Locale.php(46): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Locale->handle()
#22 /var/www/invoiceninja/app/Http/Middleware/PasswordProtection.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\PasswordProtection->handle()
#24 /var/www/invoiceninja/app/Http/Middleware/TokenAuth.php(96): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\TokenAuth->handle()
#26 /var/www/invoiceninja/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetDb->handle()
#28 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\Pipeline\Pipeline->then()
#30 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\Routing\Router->runRouteWithinStack()
#31 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\Routing\Router->runRoute()
#32 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\Routing\Router->dispatchToRoute()
#33 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\Routing\Router->dispatch()
#34 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#35 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#37 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#39 /var/www/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#40 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle()
#41 /var/www/invoiceninja/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#42 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle()
#43 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle()
#45 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#47 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#48 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#51 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#53 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#55 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Tracing\Middleware->handle()
#57 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\Pipeline\Pipeline->then()
#59 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#60 /var/www/invoiceninja/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#61 {main}
