Unkown Error in Quotes
Hey i have copied a quote and change the number of products. I can save it but when i press on the “view pdf button” i get this error:
500: DOMDocumentFragment::appendXML(): Entity: line 4: parser error : StartTag: invalid element name
i dont know what to do :confused:
Now i have an other quote, i changed the discount from percent in amount, when i press on save i get this error:
Error: please check that Invoice Ninja v5 is installed on the server
ok the error: “pleas check that…” is gone because i realoded the page while pressing F5…
Ok i got a product wich had this text
< 61 mm das 30 mm lange AP-Modul auf der Innenseite.*
now i deleted < & * and it works.
Thanks for sharing the fix!
cc @ben
