Unable to view png/jpg/jpeg documents
Running on nginx, php8.1.
v5.7.63-C146
When i upload a PDF as a document that seems to work but other than that it doesn’t work.
Also when i do a health check it says “unable to check CLI version”
Also, are you able to test with the React app?
TypeError: a.default.detectStore(…) is undefined h1-check.js
unreachable code after return statement main.foss.dart.js
GET https://www.exampledomain.com/documents/SkJWmE35JH91LvB7NRctIKXGRob7hmX9k1qZ5BuJ.jpg?=&t=1703518777328
Status 404
VersionHTTP/2
Transferred1.51 kB (2.97 kB size)
Referrer Policystrict-origin-when-cross-origin
Request PriorityHighest
DNS ResolutionSystem
Error: please check that Invoice Ninja v5 is installed on the server
Have you tried with the React app?
Just tested with react app after going to expenses → documents → click on image file to view.
404 | Nothing to see here!
In error log "directory index of “/home/username/web/domain.com/public_html/” is forbidden, " request: “GET / HTTP/2.0”
@hillel
I found this in my nginx conf
location / {
	try_files $uri $uri/ /index.php?$args;
	location ~* ^.+\.(ogg|ogv|svg|svgz|swf|eot|otf|woff|woff2|mov|mp3|mp4|webm|flv|ttf|rss|atom|jpg|jpeg|gif|png|webp|ico|bmp|mid|midi|wav|rtf|css|js|jar)$ {
		expires 30d;
		fastcgi_hide_header "Set-Cookie";
	location ~ [^/]\.php(/|$) {
		try_files $uri =404;
		include /etc/nginx/fastcgi_params;
		fastcgi_index index.php;
		fastcgi_pass unix:/run/php/php8.2-fpm-domain.org.sock;
		include /home/html/conf/web/domain.org/nginx.fastcgi_cache.conf*;
After i removed png jpg and jpeg the pictures start to work. Do you know what is the impact of removing those from the block?
@david can you please advise?
