since a month we are unable to send invoices to our clients. After addapting the .env file it’s still not possible, I’ve noticed the .log file said something about unable to generate PDF’s, the issue is even with the former generated pdf’s it’s still not possible to send the invoices per platform.
There is a 500 error.
Thnx in advance,
Yves
laravel.log
[2023-01-19 20:56:50] production.ERROR: File not found at path: 9z9GrcGOWBfKi98vkqHbrHJWylNalmLO/1pVvmmLEm8Uy8X5X32kLgyT12vVKXG21tmSLvVm5/Hd0fpWime9vCEElPsUiCjUO1UzlFeSO0zbRyBN9u/invoices/Invoice_n6PPS.pdf {“exception”:"[object] (Illuminate\Contracts\Filesystem\FileNotFoundException(code: 0): File not found at path: 9z9GrcGOWBfKi98vkqHbrHJWylNalmLO/1pVvmmLEm8Uy8X5X32kLgyT12vVKXG21tmSLvVm5/Hd0fpWime9vCEElPsUiCjUO1UzlFeSO0zbRyBN9u/invoices/Invoice_n6PPS.pdf at /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemAdapter.php:171)
#0 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemManager.php(411): Illuminate\Filesystem\FilesystemAdapter->get(‘9z9GrcGOWBfKi98…’)
#1 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\Filesystem\FilesystemManager->__call(‘get’, Array)
#2 /home/fiberpro/public_html/invoice/app/Http/Controllers/InvoiceController.php(837): Illuminate\Support\Facades\Facade::__callStatic(‘get’, Array)
#3 /home/fiberpro/public_html/invoice/vendor/symfony/http-foundation/StreamedResponse.php(109): App\Http\Controllers\InvoiceController->App\Http\Controllers\{closure}()
#4 /home/fiberpro/public_html/invoice/vendor/symfony/http-foundation/Response.php(394): Symfony\Component\HttpFoundation\StreamedResponse->sendContent()
#5 /home/fiberpro/public_html/invoice/public/index.php(61): Symfony\Component\HttpFoundation\Response->send()
#6 {main}
[previous exception] [object] (League\Flysystem\FileNotFoundException(code: 0): File not found at path: 9z9GrcGOWBfKi98vkqHbrHJWylNalmLO/1pVvmmLEm8Uy8X5X32kLgyT12vVKXG21tmSLvVm5/Hd0fpWime9vCEElPsUiCjUO1UzlFeSO0zbRyBN9u/invoices/Invoice_n6PPS.pdf at /home/fiberpro/public_html/invoice/vendor/league/flysystem/src/Filesystem.php:390)
#0 /home/fiberpro/public_html/invoice/vendor/league/flysystem/src/Filesystem.php(180): League\Flysystem\Filesystem->assertPresent(‘9z9GrcGOWBfKi98…’)
#1 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemAdapter.php(169): League\Flysystem\Filesystem->read(‘9z9GrcGOWBfKi98…’)
#2 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemManager.php(411): Illuminate\Filesystem\FilesystemAdapter->get(‘9z9GrcGOWBfKi98…’)
#3 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\Filesystem\FilesystemManager->__call(‘get’, Array)
#4 /home/fiberpro/public_html/invoice/app/Http/Controllers/InvoiceController.php(837): Illuminate\Support\Facades\Facade::__callStatic(‘get’, Array)
#5 /home/fiberpro/public_html/invoice/vendor/symfony/http-foundation/StreamedResponse.php(109): App\Http\Controllers\InvoiceController->App\Http\Controllers\{closure}()
#6 /home/fiberpro/public_html/invoice/vendor/symfony/http-foundation/Response.php(394): Symfony\Component\HttpFoundation\StreamedResponse->sendContent()
#7 /home/fiberpro/public_html/invoice/public/index.php(61): Symfony\Component\HttpFoundation\Response->send()
#8 {main}
[2023-01-20 00:00:04] production.INFO: updating currencies
[2023-01-20 06:00:04] production.INFO: Performing Autobilling 2023-01-20 06:00:04
[2023-01-20 11:34:38] production.ERROR: The process has been signaled with signal “5”. {“userId”:1,“exception”:"[object] (Symfony\Component\Process\Exception\ProcessSignaledException(code: 0): The process has been signaled with signal "5". at /home/fiberpro/public_html/invoice/vendor/symfony/process/Process.php:441)
#0 /home/fiberpro/public_html/invoice/vendor/symfony/process/Process.php(254): Symfony\Component\Process\Process->wait()
#1 /home/fiberpro/public_html/invoice/vendor/beganovich/snappdf/src/Snappdf.php(229): Symfony\Component\Process\Process->run()
#2 /home/fiberpro/public_html/invoice/app/Utils/Traits/Pdf/PdfMaker.php(44): Beganovich\Snappdf\Snappdf->generate()
#3 /home/fiberpro/public_html/invoice/app/Http/Controllers/ActivityController.php(172): App\Http\Controllers\ActivityController->makePdf(NULL, NULL, ‘<!DOCTYPE html …’)
#4 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ActivityController->downloadHistoricalEntity(Object(App\Http\Requests\Activity\DownloadHistoricalEntityRequest), Object(App\Models\Activity))
#5 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction(‘downloadHistori…’, Array)
#6 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\ActivityController), ‘downloadHistori…’)
#7 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#8 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Router.php(721): Illuminate\Routing\Route->run()
#9 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#10 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#11 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest(Object(Illuminate\Http\Request), Object(Closure), Array)
#12 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ‘100’, ‘1’)
#13 /home/fiberpro/public_html/invoice/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#14 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#15 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#16 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#17 /home/fiberpro/public_html/invoice/app/Http/Middleware/Locale.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#18 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))
#19 /home/fiberpro/public_html/invoice/app/Http/Middleware/TokenAuth.php(99): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#20 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\TokenAuth->handle(Object(Illuminate\Http\Request), Object(Closure))
#21 /home/fiberpro/public_html/invoice/app/Http/Middleware/SetDb.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#22 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDb->handle(Object(Illuminate\Http\Request), Object(Closure))
#23 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#24 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Router.php(723): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#25 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Router.php(698): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#26 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Router.php(662): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#27 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Routing/Router.php(651): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#28 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#29 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#30 /home/fiberpro/public_html/invoice/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#31 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#32 /home/fiberpro/public_html/invoice/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#33 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#34 /home/fiberpro/public_html/invoice/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#35 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))
#36 /home/fiberpro/public_html/invoice/vendor/barryvdh/laravel-debugbar/src/Middleware/InjectDebugbar.php(60): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#37 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Barryvdh\Debugbar\Middleware\InjectDebugbar->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 /home/fiberpro/public_html/invoice/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#39 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /home/fiberpro/public_html/invoice/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#42 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#43 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#44 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#45 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#46 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#47 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#48 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#49 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#50 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#51 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#52 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#53 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#54 /home/fiberpro/public_html/invoice/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#55 /home/fiberpro/public_html/invoice/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#56 {main}
