Just noticed constant traffic of about 20K to sentry2.invoicing.co. What is the reason for it? After I blocked it CPU utilization on IN dropped significantly. Is there a way to disable it.
Invoiceninja 5.3.75 with supervisor installed (2 workers)
In your accounts table set
report_errors
to 0 (false)
this will disable sentry
David, thank you so much for your help. Unfortunately
report_errors
in the database was already set to 0. I tried setting it to 1 and than back to 0 but this did not help. Is there anything else I can try?
I see the issue,
comment out line 128 of app/Exceptions/Handler
//app('sentry')->captureException($exception);
I’ll check in a fix for this.
David, I commented out the
line as you suggested, rebooted the server but it made no difference. I still see the sentry2.invoicing.co requests and high CPU utilization.
Can you add this to your .env
SENTRY_LARAVEL_DSN=example.com
And then optimize with
php artisan optimize
David, as you suggested I added the entry to the .env file, however optimize doesn’t seem to like it. I tried example.com, my own domain as well as loopback IP address. Ever time I get the following error
Looking at the error message I think the .env variable should be
SENTRY_LARAVEL_DNS=example.com
instead of
However, this change did not resolve the problem.
