The time machine button and date range dropdown selector are not working. Nothing happens when clicked or selected ???
I’m self-hosting IN with on v.2.7.2. Is this an issue for the recent update ?
Thanks for your support
Are you referring to the dashboard?
Can you check if there are any errors in storage/logs/laravel-error.log
Yes, in the dashboard.
Here is the log :
[2016-05-20 18:36:24] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:90 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(66): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(90): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(133): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(80): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9333): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9395): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9375): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9376): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9363): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8450): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8437): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8151): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(69): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8152): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8143): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8133): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2391): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(190): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(33): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/bootstrap/cache/compiled.php(3163): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/VerifyCsrfToken.php(43): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(13290): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #57 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #58 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #59 ***/bootstrap/cache/compiled.php(11846): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #60 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13029): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12966): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(3224): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 ***/bootstrap/cache/compiled.php(2338): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #82 ***/bootstrap/cache/compiled.php(2322): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #83 ***/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #84 {main} [] [] [2016-05-20 18:36:31] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:90 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(66): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(90): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(133): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(80): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9333): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9395): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9375): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9376): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9363): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8450): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8437): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8151): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(69): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8152): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8143): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8133): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2391): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(190): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(33): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/bootstrap/cache/compiled.php(3163): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/VerifyCsrfToken.php(43): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(13290): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #57 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #58 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #59 ***/bootstrap/cache/compiled.php(11846): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #60 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13029): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12966): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(3224): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 ***/bootstrap/cache/compiled.php(2338): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #82 ***/bootstrap/cache/compiled.php(2322): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #83 ***/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #84 {main} [] [] [2016-05-20 18:40:11] production.ERROR: Uncaught Error: No unicode cmap for font: {"functionName":"V","fileName":"***/public/pdf.built.js","lineNumber":7919,"columnNumber":6016} {"context":"JavaScript","user_id":1,"account_id":"1","user_name":"Alexandre Gauvin","method":"GET","url":"***/public/settings/invoice_design","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36","ip":"209.107.210.78","count":1} [] [2016-05-20 18:40:14] production.ERROR: Uncaught Error: No unicode cmap for font: {"functionName":"V","fileName":"***/public/pdf.built.js","lineNumber":7919,"columnNumber":6016} {"context":"JavaScript","user_id":1,"account_id":"1","user_name":"Alexandre Gauvin","method":"GET","url":"***/public/settings/invoice_design","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36","ip":"209.107.210.78","count":2} [] [2016-05-20 18:40:19] production.ERROR: Uncaught Error: No unicode cmap for font: {"functionName":"V","fileName":"***/public/pdf.built.js","lineNumber":7919,"columnNumber":6016} {"context":"JavaScript","user_id":1,"account_id":"1","user_name":"Alexandre Gauvin","method":"GET","url":"***/public/settings/invoice_design","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36","ip":"209.107.210.78","count":3} [] [2016-05-20 18:40:23] production.ERROR: Uncaught Error: No unicode cmap for font: {"functionName":"V","fileName":"***/public/pdf.built.js","lineNumber":7919,"columnNumber":6016} {"context":"JavaScript","user_id":1,"account_id":"1","user_name":"Alexandre Gauvin","method":"GET","url":"***/public/settings/invoice_design","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36","ip":"209.107.210.78","count":4} [] [2016-05-20 18:46:26] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:90 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(66): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(90): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(133): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(80): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9333): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9395): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9375): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9376): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9363): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8450): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8437): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8151): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(69): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8152): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8143): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8133): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2391): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(190): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(33): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/bootstrap/cache/compiled.php(3163): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/VerifyCsrfToken.php(43): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(13290): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #57 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #58 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #59 ***/bootstrap/cache/compiled.php(11846): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #60 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13029): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12966): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(3224): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(9862): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(9852): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 ***/bootstrap/cache/compiled.php(2338): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #82 ***/bootstrap/cache/compiled.php(2322): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #83 ***/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #84 {main} [] [] [2016-05-21 12:20:34] production.ERROR: Uncaught Error: No unicode cmap for font: {"functionName":"V","fileName":"***/public/pdf.built.js","lineNumber":7919,"columnNumber":6016} {"context":"JavaScript","user_id":1,"account_id":"1","user_name":"Alexandre Gauvin","method":"GET","url":"***/public/invoices/23/edit","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.102 Safari/537.36","ip":"184.162.153.243","count":1} [] [2016-08-17 20:51:47] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Undefined class constant 'KIND_SHORT' in ***/vendor/nikic/php-parser/lib/PhpParser/Parser/Php7.php:2375 Stack trace: #0 ***/vendor/nikic/php-parser/lib/PhpParser/ParserAbstract.php(247): PhpParser\Parser\Php7->reduceRule394() #1 ***/vendor/nikic/php-parser/lib/PhpParser/Parser/Multiple.php(58): PhpParser\ParserAbstract->parse('<?php\n namespac...') #2 ***/vendor/nikic/php-parser/lib/PhpParser/Parser/Multiple.php(29): PhpParser\Parser\Multiple->tryParse(Object(PhpParser\Parser\Php7), '<?php\n namespac...') #3 ***/vendor/classpreloader/classpreloader/src/ClassPreloader.php(127): PhpParser\Parser\Multiple->parse('<?php\n namespac...') #4 ***/vendor/laravel/framework/src/Illuminate/Foundation/Console/OptimizeCommand.php(83): ClassPreloader\ClassPreloader->getCode('/home/alexgauv/...', false) #5 ***/vendor/laravel/framework/src/Illuminate/Foundation/Console/OptimizeCommand.php(64): Illuminate\Foundation\Console\OptimizeCommand->compileClasses() #6 [internal function]: Illuminate\Foundation\Console\OptimizeCommand->fire() #7 ***/bootstrap/cache/compiled.php(1257): call_user_func_array(Array, Array) #8 ***/vendor/laravel/framework/src/Illuminate/Console/Command.php(169): Illuminate\Container\Container->call(Array) #9 ***/vendor/symfony/console/Command/Command.php(259): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #10 ***/vendor/laravel/framework/src/Illuminate/Console/Command.php(155): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #11 ***/vendor/symfony/console/Application.php(844): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #12 ***/vendor/symfony/console/Application.php(192): Symfony\Component\Console\Application->doRunCommand(Object(Illuminate\Foundation\Console\OptimizeCommand), Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #13 ***/vendor/symfony/console/Application.php(123): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #14 ***/vendor/laravel/framework/src/Illuminate/Console/Application.php(64): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArrayInput), Object(Symfony\Component\Console\Output\BufferedOutput)) #15 ***/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(159): Illuminate\Console\Application->call('optimize', Object(Illuminate\Support\Collection)) #16 ***/bootstrap/cache/compiled.php(6381): Illuminate\Foundation\Console\Kernel->call('optimize', Array) #17 ***/app/Http/Controllers/AppController.php(274): Illuminate\Support\Facades\Facade::__callStatic('call', Array) #18 [internal function]: App\Http\Controllers\AppController->update() #19 ***/bootstrap/cache/compiled.php(9479): call_user_func_array(Array, Array) #20 ***/bootstrap/cache/compiled.php(9541): Illuminate\Routing\Controller->callAction('update', Array) #21 ***/bootstrap/cache/compiled.php(9521): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #22 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #23 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #25 ***/bootstrap/cache/compiled.php(10004): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/bootstrap/cache/compiled.php(9522): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #27 ***/bootstrap/cache/compiled.php(9509): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #28 ***/bootstrap/cache/compiled.php(8579): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #29 ***/bootstrap/cache/compiled.php(8566): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #31 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #33 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(10004): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(8281): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #36 ***/bootstrap/cache/compiled.php(8272): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #37 ***/bootstrap/cache/compiled.php(8262): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #38 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #39 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/StartupCheck.php(193): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(41): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(51): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13517): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12010): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13256): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13193): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10019): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10004): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} [] [] [2016-09-12 22:39:15] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->ŽÚ¤†('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-12 22:39:45] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->¸Û#w('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-14 01:53:45] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-15', '2016-09-13', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-15 andinvoices
.invoice_date
<= 2016-09-13 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-15', '2016-09-13', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-15 01:15:51] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-15 01:16:08] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-15 01:41:41] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-15 02:11:04] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-15 02:30:52] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-15 09:13:06] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Call to a member function setRelation() on null in ***/app/Libraries/HistoryUtils.php:54 Stack trace: #0 ***/app/Listeners/HandleUserLoggedIn.php(51): App\Libraries\HistoryUtils::loadHistory(Array) #1 [internal function]: App\Listeners\HandleUserLoggedIn->handle(Object(App\Events\UserLoggedIn)) #2 ***/bootstrap/cache/compiled.php(10243): call_user_func_array(Array, Array) #3 [internal function]: Illuminate\Events\Dispatcher->Illuminate\Events\{closure}(Object(App\Events\UserLoggedIn)) #4 ***/bootstrap/cache/compiled.php(10188): call_user_func_array(Object(Closure), Array) #5 ***/bootstrap/cache/compiled.php(6379): Illuminate\Events\Dispatcher->fire('App\\Events\\User...') #6 ***/app/Http/Controllers/Auth/AuthController.php(142): Illuminate\Support\Facades\Facade::__callStatic('fire', Array) #7 [internal function]: App\Http\Controllers\Auth\AuthController->postLoginWrapper(Object(Illuminate\Http\Request)) #8 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #9 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('postLoginWrappe...', Array) #10 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), 'postLoginWrappe...') #11 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #16 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'postLoginWrappe...') #17 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'postLoginWrappe...') #18 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #20 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #22 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #24 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #25 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #26 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #32 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #33 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #34 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #35 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #36 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #37 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #38 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #39 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #40 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #41 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #42 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #43 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #44 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #45 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #46 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #47 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #48 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #49 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #50 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #52 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #59 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #60 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #61 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #62 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #63 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #64 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #65 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #66 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #67 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #68 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #69 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #70 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #71 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #72 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #73 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #74 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #75 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #76 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #78 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #79 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #80 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #83 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #84 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #85 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #86 {main} [] [] [2016-09-15 09:13:15] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Call to a member function setRelation() on null in ***/app/Libraries/HistoryUtils.php:54 Stack trace: #0 ***/app/Listeners/HandleUserLoggedIn.php(51): App\Libraries\HistoryUtils::loadHistory(Array) #1 [internal function]: App\Listeners\HandleUserLoggedIn->handle(Object(App\Events\UserLoggedIn)) #2 ***/bootstrap/cache/compiled.php(10243): call_user_func_array(Array, Array) #3 [internal function]: Illuminate\Events\Dispatcher->Illuminate\Events\{closure}(Object(App\Events\UserLoggedIn)) #4 ***/bootstrap/cache/compiled.php(10188): call_user_func_array(Object(Closure), Array) #5 ***/bootstrap/cache/compiled.php(6379): Illuminate\Events\Dispatcher->fire('App\\Events\\User...') #6 ***/app/Http/Controllers/Auth/AuthController.php(142): Illuminate\Support\Facades\Facade::__callStatic('fire', Array) #7 [internal function]: App\Http\Controllers\Auth\AuthController->postLoginWrapper(Object(Illuminate\Http\Request)) #8 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #9 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('postLoginWrappe...', Array) #10 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), 'postLoginWrappe...') #11 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #16 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'postLoginWrappe...') #17 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'postLoginWrappe...') #18 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #20 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #22 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #24 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #25 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #26 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #32 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #33 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #34 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #35 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #36 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #37 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #38 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #39 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #40 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #41 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #42 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #43 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #44 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #45 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #46 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #47 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #48 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #49 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #50 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #52 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #59 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #60 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #61 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #62 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #63 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #64 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #65 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #66 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #67 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #68 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #69 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #70 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #71 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #72 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #73 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #74 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #75 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #76 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #78 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #79 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #80 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #83 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #84 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #85 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #86 {main} [] [] [2016-09-15 09:38:32] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-16 14:15:32] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Call to a member function setRelation() on null in ***/app/Libraries/HistoryUtils.php:54 Stack trace: #0 ***/app/Listeners/HandleUserLoggedIn.php(51): App\Libraries\HistoryUtils::loadHistory(Array) #1 [internal function]: App\Listeners\HandleUserLoggedIn->handle(Object(App\Events\UserLoggedIn)) #2 ***/bootstrap/cache/compiled.php(10243): call_user_func_array(Array, Array) #3 [internal function]: Illuminate\Events\Dispatcher->Illuminate\Events\{closure}(Object(App\Events\UserLoggedIn)) #4 ***/bootstrap/cache/compiled.php(10188): call_user_func_array(Object(Closure), Array) #5 ***/bootstrap/cache/compiled.php(6379): Illuminate\Events\Dispatcher->fire('App\\Events\\User...') #6 ***/app/Http/Controllers/Auth/AuthController.php(142): Illuminate\Support\Facades\Facade::__callStatic('fire', Array) #7 [internal function]: App\Http\Controllers\Auth\AuthController->postLoginWrapper(Object(Illuminate\Http\Request)) #8 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #9 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('postLoginWrappe...', Array) #10 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), 'postLoginWrappe...') #11 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #16 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'postLoginWrappe...') #17 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'postLoginWrappe...') #18 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #20 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #22 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #24 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #25 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #26 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #32 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #33 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #34 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #35 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #36 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #37 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #38 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #39 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #40 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #41 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #42 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #43 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #44 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #45 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #46 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #47 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #48 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #49 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #50 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #52 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #59 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #60 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #61 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #62 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #63 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #64 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #65 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #66 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #67 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #68 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #69 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #70 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #71 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #72 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #73 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #74 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #75 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #76 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #78 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #79 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #80 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #83 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #84 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #85 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #86 {main} [] [] [2016-09-16 14:49:43] production.ERROR: Omnipay\Common\Exception\RuntimeException: Class '\Omnipay\Neteller\Gateway' not found in ***/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create('\\Omnipay\\Netell...') #1 ***/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 ***/app/Models/Gateway.php(177): Omnipay\Omnipay::__callStatic('create', Array) #3 ***/app/Http/Controllers/AccountGatewayController.php(134): App\Models\Gateway->getFields() #4 ***/app/Http/Controllers/AccountGatewayController.php(96): App\Http\Controllers\AccountGatewayController->getViewModel() #5 [internal function]: App\Http\Controllers\AccountGatewayController->create() #6 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #7 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('create', Array) #8 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), 'create') #9 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #14 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'create') #15 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'create') #16 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #17 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/app/Http/Middleware/PermissionsRequired.php(52): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #22 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #23 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #24 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #25 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #27 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #33 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #34 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #35 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #37 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #38 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #39 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #40 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #42 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #43 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #44 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #45 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #47 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #48 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #50 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #52 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #53 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #55 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #57 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #58 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #59 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #61 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #63 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #64 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #66 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #68 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #69 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #71 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #73 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #74 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #76 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #78 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #81 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #83 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #84 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #86 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #88 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #90 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #91 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #92 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #93 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #94 {main} [] [] [2016-09-18 23:56:31] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-18 23:56:46] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->xìCª9('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-18 23:57:07] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->xì£3è('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-18 23:59:45] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-20 andinvoices
.invoice_date
<= 2016-09-18 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:47] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:49] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:49] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-20 andinvoices
.invoice_date
<= 2016-09-18 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:50] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:51] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:53] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-12', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-09-12 andinvoices
.invoice_date
<= 2016-09-18 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-12', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-18 23:59:59] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-20 andinvoices
.invoice_date
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 00:00:00] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 00:00:01] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-01', '2016-09-30', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-09-01 andinvoices
.invoice_date
<= 2016-09-30 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-01', '2016-09-30', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 00:00:07] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-10', '2016-09-13', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-10 andinvoices
.invoice_date
<= 2016-09-13 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-10', '2016-09-13', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 00:00:11] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-10', '2016-09-13', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-10', '2016-09-13', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 01:18:44] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->xìÃÛ('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-19 01:18:54] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->8('http://compta.a...', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('http://compta.a...') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-19 01:19:08] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-20 andinvoices
.invoice_date
<= 2016-09-18 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 01:19:09] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 01:19:09] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-20', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-20', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 01:19:11] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-09-12', '2016-09-18', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-09-12 andinvoices
.invoice_date
<= 2016-09-18 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-09-12', '2016-09-18', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:43:39] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-21', '2016-09-19', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-21 andinvoices
.invoice_date
<= 2016-09-19 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-21', '2016-09-19', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:43:41] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-21', '2016-09-19', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-21', '2016-09-19', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:43:43] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-01', '2016-09-30', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-09-01 andinvoices
.invoice_date
<= 2016-09-30 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-09-01', '2016-09-30', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:43:45] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-09-01', '2016-09-30', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-09-01', '2016-09-30', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:44:08] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-21', '2016-09-19', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-21 andinvoices
.invoice_date
<= 2016-09-19 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-21', '2016-09-19', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:44:09] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-21', '2016-09-19', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-21', '2016-09-19', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-19 10:44:10] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-21', '2016-09-19', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-21', '2016-09-19', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-21 20:51:53] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-23', '2016-09-21', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-23 andinvoices
.invoice_date
<= 2016-09-21 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-23', '2016-09-21', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-21 20:51:54] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-23', '2016-09-21', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-23', '2016-09-21', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-21 21:16:59] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Call to a member function setRelation() on null in ***/app/Libraries/HistoryUtils.php:54 Stack trace: #0 ***/app/Listeners/HandleUserLoggedIn.php(51): App\Libraries\HistoryUtils::loadHistory(Array) #1 [internal function]: App\Listeners\HandleUserLoggedIn->handle(Object(App\Events\UserLoggedIn)) #2 ***/bootstrap/cache/compiled.php(10243): call_user_func_array(Array, Array) #3 [internal function]: Illuminate\Events\Dispatcher->Illuminate\Events\{closure}(Object(App\Events\UserLoggedIn)) #4 ***/bootstrap/cache/compiled.php(10188): call_user_func_array(Object(Closure), Array) #5 ***/bootstrap/cache/compiled.php(6379): Illuminate\Events\Dispatcher->fire('App\\Events\\User...') #6 ***/app/Http/Controllers/Auth/AuthController.php(142): Illuminate\Support\Facades\Facade::__callStatic('fire', Array) #7 [internal function]: App\Http\Controllers\Auth\AuthController->postLoginWrapper(Object(Illuminate\Http\Request)) #8 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #9 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('postLoginWrappe...', Array) #10 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), 'postLoginWrappe...') #11 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #12 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #13 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #16 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\Auth\AuthController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'postLoginWrappe...') #17 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'postLoginWrappe...') #18 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #20 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #21 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #22 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #24 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #25 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #26 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #29 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #31 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #32 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #33 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #34 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #35 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #36 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #37 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #38 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #39 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #40 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #41 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #42 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #43 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #44 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #45 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #46 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #47 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #48 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #49 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #50 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #52 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #59 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #60 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #61 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #62 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #63 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #64 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #65 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #66 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #67 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #68 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #69 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #70 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #71 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #72 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #73 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #74 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #75 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #76 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #78 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #79 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #80 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #83 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #84 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #85 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #86 {main} [] [] [2016-09-22 18:24:28] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-24', '2016-09-22', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-24 andinvoices
.invoice_date
<= 2016-09-22 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-24', '2016-09-22', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:24:28] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-24', '2016-09-22', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-24', '2016-09-22', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:24:31] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-01', '2016-08-31', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-01 andinvoices
.invoice_date
<= 2016-08-31 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-01', '2016-08-31', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:24:33] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-01', '2016-08-31', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-01', '2016-08-31', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:24:33] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-01', '2016-08-31', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-01', '2016-08-31', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:24:34] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-01', '2016-08-31', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-01 andinvoices
.invoice_date
<= 2016-08-31 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-01', '2016-08-31', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:59:32] production.ERROR: Symfony\Component\Debug\Exception\FatalThrowableError: Class 'Illuminate\Http\RedirectResponse' not found in ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php:188 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Routing/Redirector.php(117): Illuminate\Routing\Redirector->('https://compta....', 302, Array) #1 ***/bootstrap/cache/compiled.php(6379): Illuminate\Routing\Redirector->to('https://compta....') #2 ***/app/Http/Controllers/AppController.php(299): Illuminate\Support\Facades\Facade::__callStatic('to', Array) #3 [internal function]: App\Http\Controllers\AppController->update() #4 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #5 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('update', Array) #6 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), 'update') #7 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #8 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #9 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #10 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #11 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #12 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AppController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'update') #13 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'update') #14 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #16 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #17 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #19 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #21 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #22 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #23 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #24 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #28 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #30 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #32 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #33 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #34 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #49 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #50 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #51 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #52 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #53 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #54 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #55 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #56 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #57 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #58 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #79 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #80 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #81 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #82 {main} [] [] [2016-09-22 18:59:46] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-24', '2016-09-22', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.SEMAINE does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), SEMAINE(invoice_date)) as SEMAINE frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
>= 2016-08-24 andinvoices
.invoice_date
<= 2016-09-22 and (clients.currency_id = 9 or coalesce(clients.currency_id, 0) = 0) andinvoice_type_id
= 1 andis_recurring
= 0 group bySEMAINE
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'SEMAINE', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Semaine', '2016-08-24', '2016-09-22', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:59:46] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-24', '2016-09-22', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.MOIS does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), MOIS(invoice_date)) as MOIS frominvoices
left joinclients
onclients
.id
=invoices
.client_id
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byMOIS
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'MOIS', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Mois', '2016-08-24', '2016-09-22', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] [] [2016-09-22 18:59:46] production.ERROR: PDOException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:333 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(333): PDO->prepare('select sum(invo...') #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'select sum(invo...', Array) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #4 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #5 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #6 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #7 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #8 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-24', '2016-09-22', '9', false) #9 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #10 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #11 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #12 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #15 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #16 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #17 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #18 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #19 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #20 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #21 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #23 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #24 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #25 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #26 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #27 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #29 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #31 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #32 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #33 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #34 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #35 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #36 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #37 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #38 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #39 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #40 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #41 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #42 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #43 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #44 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #45 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #46 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #47 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #48 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #49 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #50 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #51 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #52 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #53 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #54 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #55 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #56 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #57 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #58 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #59 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #60 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #61 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #62 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #63 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #64 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #65 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #66 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #67 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #68 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #69 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #70 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #71 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #72 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #73 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #74 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #75 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #76 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #77 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #78 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #79 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #80 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #81 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #83 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #84 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #85 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #86 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #88 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #89 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #90 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #91 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #92 {main} Next Illuminate\Database\QueryException: SQLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION alexgauv_ninj615.JOUR does not exist (SQL: select sum(invoices.amount) as total, count(invoices.id) as count, concat(YEAR(invoice_date), JOUR(invoice_date)) as JOUR frominvoices
left joinclients
onclients
.id
=invoices
.client_id
where (clients.id IS NULL OR clients.is_deleted = 0) andinvoices
.account_id
= 1 andinvoices
.is_deleted
= 0 andinvoices
.invoice_date
.invoice_date
= 1 andis_recurring
= 0 group byJOUR
) in ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729 Stack trace: #0 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback('select sum(invo...', Array, Object(Closure)) #1 ***/vendor/laravel/framework/src/Illuminate/Database/Connection.php(349): Illuminate\Database\Connection->run('select sum(invo...', Array, Object(Closure)) #2 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1610): Illuminate\Database\Connection->select('select sum(invo...', Array, true) #3 ***/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(1596): Illuminate\Database\Query\Builder->runSelect() #4 ***/app/Ninja/Repositories/DashboardRepository.php(47): Illuminate\Database\Query\Builder->get() #5 ***/app/Http/Controllers/DashboardController.php(101): App\Ninja\Repositories\DashboardRepository->chartData(Object(App\Models\Account), 'JOUR', Object(DateTime), Object(DateTime), '9', false) #6 [internal function]: App\Http\Controllers\DashboardController->chartData('Jour', '2016-08-24', '2016-09-22', '9', false) #7 ***/bootstrap/cache/compiled.php(9478): call_user_func_array(Array, Array) #8 ***/bootstrap/cache/compiled.php(9540): Illuminate\Routing\Controller->callAction('chartData', Array) #9 ***/bootstrap/cache/compiled.php(9520): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), 'chartData') #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #11 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #13 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 ***/bootstrap/cache/compiled.php(9521): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 ***/bootstrap/cache/compiled.php(9508): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\DashboardController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'chartData') #16 ***/bootstrap/cache/compiled.php(8578): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), 'App\\Http\\Contro...', 'chartData') #17 ***/bootstrap/cache/compiled.php(8565): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 ***/bootstrap/cache/compiled.php(8279): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #20 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 ***/app/Http/Middleware/Authenticate.php(90): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user') #23 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #25 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #27 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #28 ***/bootstrap/cache/compiled.php(8280): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #29 ***/bootstrap/cache/compiled.php(8271): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #30 ***/bootstrap/cache/compiled.php(8261): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #31 ***/bootstrap/cache/compiled.php(2419): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #32 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request)) #33 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #34 ***/app/Http/Middleware/StartupCheck.php(194): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #35 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #36 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #37 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #38 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 ***/app/Http/Middleware/SessionDataCheckMiddleware.php(29): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: App\Http\Middleware\SessionDataCheckMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #43 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 ***/app/Http/Middleware/QueryLogging.php(28): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #48 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 ***/app/Http/Middleware/DuplicateSubmissionCheck.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #50 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #52 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #53 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #54 ***/bootstrap/cache/compiled.php(3225): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #55 ***/app/Http/Middleware/VerifyCsrfToken.php(54): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #56 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #59 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 ***/bootstrap/cache/compiled.php(13527): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #64 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 ***/bootstrap/cache/compiled.php(12017): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #69 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 ***/bootstrap/cache/compiled.php(13266): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #74 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 ***/bootstrap/cache/compiled.php(13203): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #79 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 ***/bootstrap/cache/compiled.php(3286): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #81 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #82 ***/bootstrap/cache/compiled.php(10017): call_user_func_array(Array, Array) #83 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request)) #84 ***/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #85 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request)) #86 ***/bootstrap/cache/compiled.php(10002): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #87 ***/bootstrap/cache/compiled.php(2366): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #88 ***/bootstrap/cache/compiled.php(2350): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #89 ***/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #90 {main} [] []
It looks like the problem is happening when using fr_CA, you can test in English by adding ?lang=en to the end of the URL.
We’ll include a fix in our next minor release.
Yeah, it’s in english and fr-FR.
Could it be a mispelled string in the fr_CA texts.php ? Since I did most of the translating for this local, I could fix it if you can tell me where it is ??
The translations are fine, it’s a problem in the code.
Thaks for your support
Of course, thanks for helping debug the problem!
Here’s the fix if you want to patch your code.
https://github.com/invoiceninja/invoiceninja/commit/d146fee67ceaa205119dfb962c16bfc172bc7ba9
It will be include in v2.7.3 next week.
Wow !
That was lightning fast.
Thanks a lot.
