In my effort to adapt the french translation of IN, I did modify the Invoice Statuses table entries. It seems that I broke something as of mow, only “texts.status_brouillon” appears in place of the french label Brouillon (draft)
I looked everywhere to repair my mistake without success. Could you point me out to the correct info ?
You can run php artisan db:seed --class=InvoiceStatusSeeder to reset the invoice status values. You’ll likely also need to add ?clear_cache=true to the URL to clear the cache.
Thanks for your support. Sorry for my ignorance but how do I use that.
I did try into regular command line but returns me with a parse error and -bash: make:console: command not found
. How should I access to artisan mode ?
I did try to read a bit on Laravel artisan framework but I overpassed my point of knowleddge in that matter ;(
You’ll need to run it from within the root folder of the project. An alternative would be to manually update the invoice_statuses table back to the old values.
