I’m using the “bold” template for my invoices and quotes. When I create a big invoice or quote, the text of my line items is under the footer-layer. I thought setting a page-margin would solve this problem, but the page margin also affects the position of the footer. One way to avoid is, is to only show the footer on the last page, but I would like to show the footer on every page.
I have the same problem. On which tab can I adjust the page margin? Footer position can be adjusted on tab footer I suppose. There I have the following values:
I didn’t want to create a new thread for something that is exactly the same as described here. I’ve re-re-re-read everything a couple of times and I still can’t seem to get it to work. I’m using the business template and even after applying everything that’s written here I still get an overlap (4.5.17).
Could you give me an idea on how to do it with the default business template please?
Hillel, this will only change the “position” of the footer if I’m not mistaken. This doesn’t change the fact that the Terms are overlapping the footer.
