Hello!
Thanks for a great product!
I’m facing a little trouble after an upgrade from 4.5.12 to 4.5.13 all was working fine until i did the update. Now to the info.
Invoice Ninja.
- Host Type:Self-Hosted White Label 4.5.12 (HostGator -SharedHosting)
<li>Domain or Sub-domai: Sub-domain.(ninja.mydomain.com)</li>
<li>Problem Type: After Upgrade</li>
<li>Procedure: Backup MySQLDB using CPanel, Copy files over FTP. Got some errors no working page, change again via phpSelector the version of php in /public folder to 7.1, tried main url load correctly. Use ninja.mydomain/update, get notification about a successful update to 4.5.13.
Log in, checks all is working properly but System Settings. If i tried to use the Database Connection test or Email Settings i get a POST 406 error in console.
Error Detail in Chrome Console
POST https://crm.oroq.com/setup 406 - jquery.js:9664
send @ jquery.js:9664
ajax @ jquery.js:9215
ot.<computed> @ jquery.js:9361
testDatabase @ system_settings:1039
onclick @ system_settings:998
<li>If i tried to save the settings i get a text page - https://ninja.mydomain.com/update_setup
" Not Acceptable!
An appropriate representation of the requested resource could not be found on this server. This error was generated by Mod_Security."
Errors Logs:
[03-Jul-2019 21:42:14 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:16 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:17 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:19 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:20 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:24 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:32 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
[03-Jul-2019 21:42:36 UTC] PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
Multiple times in the log file like 3 or 4 times per minute.
Laravel Error Logs. - No recents errror.
Things i tried.
- Cleared Cache.
<li>Uncommenting - RewriteBase / in .htaccess after i did the update</li>
<li>Enabling Debug - No visible error.</li>
<li>Using Chrome Mobile</li>
Greetings,
A fellow human.
