I’m using invoiceninja.com, and I’ve used my google account to login in the past. However, I’d now like to login to my account using standard username/password.
Is there a way to change the login details?
Duncan
Duncan
You can set a password using the ‘recover password’ link on the login screen.
Thanks for the reply. So, I’ve reset my password succesfully, and can log in with my googlemail address.
Can I change the email address that I use to login?
Duncan
You can change your email address on Settings > User Details
Not sure how I missed that!
Thanks for your help.
