getting an 500 error when client tries to make an invoice payment via Stripe gateway,
TypeError:
App\Jobs\Invoice\CheckGatewayFee::__construct(): Argument #1 ($invoice_id) must be of type int, App\Models\Invoice given, called in /var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Bus/Dispatchable.php on line 18
at /var/www/gpsdata.io/billing/app/Jobs/Invoice/CheckGatewayFee.php:32
at App\Jobs\Invoice\CheckGatewayFee->__construct()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Bus/Dispatchable.php:18)
at App\Jobs\Invoice\CheckGatewayFee::dispatch()
(/var/www/gpsdata.io/billing/app/Services/ClientPortal/InstantPayment.php:203)
at App\Services\ClientPortal\InstantPayment->run()
(/var/www/gpsdata.io/billing/app/Http/Controllers/ClientPortal/PaymentController.php:88)
at App\Http\Controllers\ClientPortal\PaymentController->process()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Controller.php:54)
at Illuminate\Routing\Controller->callAction()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php:43)
at Illuminate\Routing\ControllerDispatcher->dispatch()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Route.php:260)
at Illuminate\Routing\Route->runController()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Route.php:205)
at Illuminate\Routing\Route->run()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php:798)
at Illuminate\Routing\Router->Illuminate\Routing\{closure}()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:141)
at Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
(/var/www/gpsdata.io/billing/app/Http/Middleware/QueryLogging.php:39)
at App\Http\Middleware\QueryLogging->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:180)
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php:50)
at Illuminate\Routing\Middleware\SubstituteBindings->handle()
(/var/www/gpsdata.io/billing/app/Http/Middleware/Locale.php:46)
at App\Http\Middleware\Locale->handle()
(/var/www/gpsdata.io/billing/app/Http/Middleware/CheckClientExistence.php:32)
at App\Http\Middleware\CheckClientExistence->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php:44)
at Illuminate\Auth\Middleware\Authenticate->handle()
(/var/www/gpsdata.io/billing/app/Http/Middleware/SetDomainNameDb.php:39)
at App\Http\Middleware\SetDomainNameDb->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php:78)
at Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php:49)
at Illuminate\View\Middleware\ShareErrorsFromSession->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php:37)
at Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
(/var/www/gpsdata.io/billing/app/Http/Middleware/SessionDomains.php:31)
at App\Http\Middleware\SessionDomains->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:121)
at Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:64)
at Illuminate\Session\Middleware\StartSession->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php:67)
at Illuminate\Cookie\Middleware\EncryptCookies->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:116)
at Illuminate\Pipeline\Pipeline->then()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php:799)
at Illuminate\Routing\Router->runRouteWithinStack()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php:776)
at Illuminate\Routing\Router->runRoute()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php:740)
at Illuminate\Routing\Router->dispatchToRoute()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php:729)
at Illuminate\Routing\Router->dispatch()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:190)
at Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
(/var/www/gpsdata.io/billing/vendor/livewire/livewire/src/DisableBrowserCache.php:19)
at Livewire\DisableBrowserCache->handle()
(/var/www/gpsdata.io/billing/app/Http/Middleware/Cors.php:25)
at App\Http\Middleware\Cors->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php:39)
at Illuminate\Http\Middleware\TrustProxies->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php:21)
at Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php:31)
at Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php:40)
at Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php:27)
at Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php:86)
at Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:165)
at Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
(/var/www/gpsdata.io/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:134)
at Illuminate\Foundation\Http\Kernel->handle()
(/var/www/gpsdata.io/billing/public/index.php:57)
