Stop recurring invoices and rerun not work
After seeing a problem with recurring invoices not being created, I see and make corrections to the problem.
Error and corrections
  • System upgraded to php 8.3 and upgrade not install mysql pdo extension.
  • Install all extensions for php8.3
  • run cd /home/laravel/web/clientes.aicha.es && php artisan schedule:run Now no problem when run.
Remaining problem
Now I check my recurring invoices.
Since day 1 of this month, no recurring invoice has been created.
Logging and debug
I put debug in invoice ninja, via, .env EXPANDED_LOGGING=true
I don’t know if there is any way to force the review of recurring invoices that were not created to be run. It’s possible? As?
Installed version
  • v5.7.62-C145
@david can you please advise?
After upgrading and checking too many errors… (Changes on PDF, libraries for PDF, install supervisor instead of older method,…). work fine.
All older recurring invoices are generated.
A bit complex for normal users. If are not a programmer, you can die trying. :joy:
