Maybe I’m completely overlooking something here but when I load an invoice or save an invoice it is automatically printing to PDF which is really annoying. How do I turn that off? This is happening in FF. I believe Chrome does the same thing.
Can you confirm if you’re seeing the problem in Chrome as well, it’s a known issue with Firefox.
https://support.mozilla.org/en-US/kb/view-pdf-files-firefox-without-downloading-them
You can force the app to use a JavaScript PDF renderer by loading /force_inline_pdf
You’re right. Doesn’t do it in Chrome. How do I fix FF? I"m unclear from your answer.
I could fix this by changing the pdf settings in Options > Applications to show pages in FF.
Don’t have an English FF here, but if you go to Options > Applications and do a search for pdf it will hopefully be clear what needs to be done.
Thanks for sharing your solution!
I am having a similar issue using Chrome on Android. Whenever I login and go to view one of my invoices, it keeps auto downloading the invoice over and over again. Anyone have a solution for this?
You can make the app to use a JavaScript based PDF renderer by loading /force_inline_pdf
Where do I do this exactly?
BTW, I didn’t intend to hijack someone else’s thread, but I don’t see an +new topic button anywhere. Is there one to be found one here?
In your browser. ie, load https://site.com/force_inline_pdf (or /public/force_inline_pdf)
There should be an option to create a new post at the bottom of this page:
