Stock Quantity always negtavie
whatever I do, product Stock Quantity is negative value??
I want to track the inventory
Any idea?
There are two ways to increase the product’s inventory:
  • Edit the product and manually set a new stock amount
  • Have a purchase order accepted and then added to inventory
Thanks for your reply…
But I tried “Edit the product and manually set a new stock amount”… after save it change to negative.
Can you reproduce this in the demo: https://demo.invoiceninja.com
If you can share a screen recording it may help.
