Square Integration
This webpage Square - Invoice Ninja states
“Combining Square with your Invoice Ninja account can be done in just a few clicks.”
However I can’t find any documentation on this “few click” setup.
Here are the steps:
  • Navigate to Settings > Payment Settings > Configure Gateways
  • Click ‘Create’ at the top
  • Select Square and provide the credentials
Thanks. I’ll give it a shot. I see someone else asked about creating the access credentials for Square so I’ll use that too.
If I understand the instructions correctly to get the credentials I need to follow the directions on this page.
Is that correct?
If so which credentials?
Personal access token or OAuth access token?
@david can you please advise?
