SQL Backups Decreasing in Size
Any particular reason after the most reason update v4.5.9 that my SQL Database backups are much smaller in size? Doesn’t appear to be any data loss just a much smaller SQL Dump.
Extremely silly mistake of the backup partition being full, need to adjust my rotate settings. Please remove post if possible has nothing to do with this great billing platform.
